In Tank Fuel Pump For Carburetors - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 9th, 19, 03:34 PM Thread Starter
Larry
Did a little bit of searching but haven't found too much...
I need to install a fuel pump in the tank of a 69 preferably using the factory style sender. My first thought is to find a low pressure pump with barb fittings and somehow plumb it inline with the sender but it's gonna be a tight fit. Or one with the sock mounted to the bottom of the pump and plumb it in from there.
Is there a a plug and play system out there ready to go?
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #2 of 5 (permalink) Old Dec 9th, 19, 04:16 PM
Darin
ilikeike's Avatar
Re: In Tank Fuel Pump For Carburetors
I don't have anything to offer as far as the factory sender, but I installed the Tanks inc. setup for EFI,ran that for a year, then changed my regulator and now run a carb.
Everything the same just need to swap the regulator back when I go to an MPFI setup in the future.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 5 (permalink) Old Dec 9th, 19, 04:43 PM
https://www.holley.com/products/fuel...s/parts/19-365
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 5 (permalink) Old Dec 9th, 19, 07:32 PM
Vega$69's Avatar
I like the Holley set up but still will require trunk pan mod.
Vega$69 is offline
post #5 of 5 (permalink) Old Dec 10th, 19, 05:47 AM
The Spectra tank and pump set-up has worked very well for me.
https://www.summitracing.com/parts/sgt-gm32bfi
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is online now
