327 rockers - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 13th, 20, 08:16 AM Thread Starter
danny
327 rockers
When I’m replacing the rockers is there anything I need to be carefully about when choosing replacements?
camarolover#1 is offline
post #2 of 10 (permalink) Old Jan 13th, 20, 08:34 AM Thread Starter
danny
Does anyone suggest a “brand” And/or “ratio” to go with ?
post #3 of 10 (permalink) Old Jan 13th, 20, 10:00 AM
Chris
Re: 327 rockers
I went with Harland Sharp 1.5 full roller rockers. It depends on what youíre trying to get out of the engine. Stamped steel, stock type, obviously work, but if youíve beefed up the engine, you may want something stouter. IMO you canít go wrong with a roller tip or full roller rocker arm. Unless youíre wanting to keep it stock, Iíd recommend an upgrade to a roller tip or full roller.
You will need ones that self align unless you are running guide plates, which you are likely not. I think Comp Cams makes a nice 1.52:1 roller tip that is a good upgrade.
ChrisG is offline
post #4 of 10 (permalink) Old Jan 13th, 20, 12:11 PM
bob
Re: 327 rockers
Very good advise.
If you're stock, keep the 1.5:1 stamped steel rockers. Nothing wrong with them.
If you have adjustable guide plates and want to step up in performance, the Comp Cam 1601 Pro Magnums are very nice and extremely durable.
bob15 is offline
post #5 of 10 (permalink) Old Jan 13th, 20, 12:11 PM
R66
Ron
Re: 327 rockers
Depends:
Rebuild with GM parts or specifications (even HP parts) and used primarily as a cruiser with occasional racing application, the long slot stamped steel rockers (1.5 std) will serve you well for over 100K miles. Even the 302 and high HP 350s used these rockers.
Rebuild with aftermarket high lift cams, stronger springs, etc. setup primarily for racing applications: rockers, pushrods, guides, girdles, etc. as recommended by the cam manufacturer. But then again, why not go with aluminum heads?
I ran some aluminum roller rockers on a 302 and still had valve train problems, I am not a big fan of super duper aftermarket parts for a cruiser.
Ron
R66 is offline
post #6 of 10 (permalink) Old Jan 13th, 20, 12:15 PM Thread Starter
danny
The motor is all stock and I just want to upgrade them.
post #7 of 10 (permalink) Old Jan 13th, 20, 06:34 PM
scblucam's Avatar
Re: 327 rockers
If you do go with rollers and guide plates you will need hardened pushrods and you should go with screw in studs as yours may be pressed in. If you go that far aluminum heads are not all that expensive.
68 302 M20 - 85 IROC Z
scblucam is offline
post #8 of 10 (permalink) Old Jan 13th, 20, 07:57 PM
kevin
Re: 327 rockers
the studs can be pinned
flat tire is offline
post #9 of 10 (permalink) Old Jan 13th, 20, 08:01 PM
Vega$69's Avatar
Re: 327 rockers
I like the Harland Sharps or Roller Tipped Stamped.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #10 of 10 (permalink) Old Jan 13th, 20, 08:08 PM
Re: 327 rockers
Originally Posted by camarolover#1 View Post
When Iím replacing the rockers is there anything I need to be carefully about when choosing replacements?
If this is a fresh stock build than new stock stamped 1:5 will be fine and trouble free for at least 100k mi.
Upgrade....then a stamped 1:5 with a roller tip SA
If it was a head & cam build than a full roller RR 1:6 (Comp Pro Mag) NSA using guide plates & hardened PR
SoCal805 is online now
