I Finally Pulled The Trigger! EFI Going On My 396 - Team Camaro Tech
 7Likes
post #1 of 22 (permalink) Old Jan 17th, 20, 03:32 AM Thread Starter
Brett
I made this purchase, hoping it is a good purchase. Part of this is used, but the ECU is brand new as well as the 3.5 display. This setup contains a FAST Dual Sync Dizzy. The harness has been altered with a connector added instead of the adapter purchased from Holley. I just purchased a MSD Dual Sync P/N 23753 and I will restore the harness back to the original setup.
I hope to use a cable accelerator setup. I purchased some parts to make the conversion but I do not know if my original pedal can still be used with a cable setup. I purchased a new pedal and will post the parts when they arrive.
I purchased a Holley P/N 12-300 OE Style In-Tank fuel pump. The EFI setup I purchased is from a guy that included a fuel pump relay and fused wiring harness.
I am excited to be installing a new technology system in my 50 year old car. This will be a fun project!
Brett.....
wireboy355 likes this.
Rockets Up In 2020!
Brettallen59 is offline
post #2 of 22 (permalink) Old Jan 17th, 20, 04:30 AM
Greg
pittpens24's Avatar
Re: I Finally Pulled The Trigger! EFI Going On My 396
I have been on the fence for my next build for adding EFI. Very interested to see your results and feedback of a system like this. Oh and congrats on having the balls to upgrade!
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #3 of 22 (permalink) Old Jan 17th, 20, 07:25 AM
Darin
ilikeike's Avatar
When you get it all done and running well, take it to a tuner with a chassis dyno, those canned tunes that are in the ECU are weak compared to what a good tuner will put to the rear wheels.
I went up around 40Hp @ the wheels after a dyno tune, then it actually matched what my lap top dyno program had estimated.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #4 of 22 (permalink) Old Jan 17th, 20, 07:29 AM
Vega$69's Avatar
You can use a 6 cyl pedal with a cable.
https://www.summitracing.com/parts/o...iABEgLJEPD_BwE
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 22 (permalink) Old Jan 17th, 20, 08:14 AM
kevin
make sure you do the pedal change before you put the top end on . it will give you a LITTLE more room to get to the pedal bolts
flat tire is offline
post #6 of 22 (permalink) Old Jan 17th, 20, 09:26 AM
Congrats on the buy, Brett, and I'm sure it is monies well spent.
Yes, John gave a good suggestion getting a L6 pedal.
Make a notebook of the events you do as they will be good for future reference, and for others here wanting to change over.
I'm curious on the O2 sensor and its fitment into the system.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #7 of 22 (permalink) Old Jan 17th, 20, 09:27 AM
Nice! I have a terminator system to start installing. I’m very excited. I’ll be following your thread.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is online now
post #8 of 22 (permalink) Old Jan 17th, 20, 02:35 PM
Alex
Awesome, you are going to love it!
I went with the Terminator Stealth in black, the HP ECU, dual-sync dizzy, and the MSD 6EFI box. I've mounted my ECU and MSD box under my dash. I added an oil temp sensor and fuel pressure sensor. I'm just running an in-line pump for now until I get a proper PWM in-tank fuel pump setup from VaporWorx and a new baffled fuel cell. I'm going to head down to Westech for my dyno tune since I'm in SoCal.
1969 Pontiac Firebird
w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black w/black interior.
1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
anguilla1980 is offline
post #9 of 22 (permalink) Old Jan 17th, 20, 05:45 PM Thread Starter
Brett
This multi-quote I have NEVER got it to work. I click on each one I want to reply to, then I click on "Multi-quote", then I go to my reply and there is nothing there to click on!
Anyway, John, look at this one below. It sure looks like the one you recommended.
Camaro Gas Pedal
The guy I purchased the setup from sent me a tune. We will see how it goes.
I have tried and tried to tune this Holley 750 and I finally said F-it, I am going to go the route with better throttle response, better idle, better gas mileage, more power and more fun driving it. I know I can get better performance all around with EFI over the old school Holley.
I grew bigger balls when I saw the opportunity to get into EFI and save $1500!
I will give updates, but they wont be super quick. We are swamped at work and I don't get to spend a lot of time working on the 69. Sometimes, when i have only one day off, I wind up sleeping all day!
Rockets Up In 2020!
Brett....
Rockets Up In 2020!
post #10 of 22 (permalink) Old Jan 17th, 20, 06:45 PM
I would recommend a Lokar universal cable since I had a "stock replacement" take a dump on me in less than a dozen drives.
IF the cable fails, it's an easy replacement too.
To remove/replace the bracket at the firewall (2 bolts) use a ratchet wrench with a swivel head.....it TIGHT
I forget the size... 5/16" ? maybe ???
68 Camaro~LSx ~all motor
post #11 of 22 (permalink) Old Jan 17th, 20, 06:56 PM
Vega$69's Avatar
To multi quote. Hit multi quote in each post you want to quote except the last one hit quote and it should work.
yellow69RS likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 22 (permalink) Old Jan 17th, 20, 06:57 PM
Vega$69's Avatar
And yes that is the pedal. I would also use the Lokar universal for cable with it
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 22 (permalink) Old Jan 18th, 20, 06:50 PM Thread Starter
Brett
I purchased the pedal and a cable, but the cable seems too short. I do not see how it fits to the pedal. This is the cable I bought; Summit Throttle Cable . There is this universal Lokar, but I don't see how this one mounts to my new pedal; Summit Universal Cable
If you have a part number or link to the cable that will work that would be great.
Thanks,
Brett.....
Rockets Up In 2020!
post #14 of 22 (permalink) Old Jan 22nd, 20, 06:06 PM
Carl
Is there an advantage of the cable throttle? I have this same kit, and while great, the throttle is SUPER sensitive and takes away from the streetability of it all.
blackmagik3 is offline
post #15 of 22 (permalink) Old Jan 22nd, 20, 06:55 PM
scblucam's Avatar
Lokar makes a dedicated Camaro pedal assembly with a cable
Just 1 More likes this.
68 302 M20 - 85 IROC Z
scblucam is online now
