67 Hood Vents - Engine Heat - Page 2 - Team Camaro Tech
 15Likes
post #16 of 32 (permalink) Old Feb 8th, 20, 06:00 AM
Vega$69's Avatar
Re: 67 Hood Vents - Engine Heat
You went with a big cube motor that that produces a lot of heat relative to the power produced.
The under hood air temp is not causing your engine temp issue and opening the small louver area is not going to help at all.
You can remove/modify the inner fenders but the bottom line is you need more cooling capacity. Bigger radiator and more CFM. You can also try a different coolant like Evans.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #17 of 32 (permalink) Old Feb 8th, 20, 08:10 AM
Yep better radiator with dual Spal fans and a full shroud. I would talk to C&R. One of their radiators with an oil cooler might be worth considering.
Hood vents can help at speed but wonít address your idling issue.
Deangelo66 likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #18 of 32 (permalink) Old Feb 8th, 20, 08:11 AM
kevin
have you ever tried a mechanical fan?
I made top and bottom filler panels which force the air to go through the radiator, so it has no place else to go but through the radiator
flat tire is offline
post #19 of 32 (permalink) Old Feb 8th, 20, 10:00 AM Thread Starter
DeAngelo
Great point! You are in line with others. That is exactly what I will do. Bigger radiator with maybe a custom shroud and a closeout panel. C and R and Cold case are my options. I emailed Cold Case, but am unsure if they do custom work.
Thanks! I will def contact them. And wouldn't one big fan cover more area than two small fans?Kind of like one big circle in a square covers more area than two circles in a square? The connecting smaller circles will have gaps. Am I thinking incorrectly?
Thanks! I am def getting a closeout panel! I hope to stay with an electric fan.
67 Camaro RS/SS
598 Crate Motor (original 350 on engine stand)
4L80e
Deangelo66 is offline
post #20 of 32 (permalink) Old Feb 8th, 20, 10:48 AM
One fan doesnít necessarily pull more air than two. Itís all about CFM ratings, not area. Even then be careful because it is so easy to manipulate CFM specs. Thatís why I said Spal, they are reasonably trustworthy in their ratings.
post #21 of 32 (permalink) Old Feb 8th, 20, 10:54 AM Thread Starter
DeAngelo
Gotcha! Thanks, Don!
bill3337 likes this.
67 Camaro RS/SS
4L80e
post #22 of 32 (permalink) Old Feb 8th, 20, 03:51 PM
Bigger is better with radiators. I had a 582 in an Impala taxi cab that ran 9.30's. But I cooled it with a Griffin twin one and a quarter inch tube size radiator designed to fit an 1987 Suburban truck with a BBC and automatic. I had to drop the lower mounting bracket to close my flat hood and I had removed the factory A/C and was running a huge oil cooler for the transmission in it's place. Even if you have a manual tranny you want an automatic radiator because the fin count is higher with the automatic radiator (more surface area to cool with) .
One final note don't buy your radiator new. NASCAR makes the race houses take their cars apart every year a nd build a new one from the ground up. You can find a used C&R radiator designed to cool a thousand horsepower for less than the price of a new Griffin. (depending upon the time of the year).
https://www.circletracksupply.com/radiators/
https://www.hotrod.com/articles/how-...-nascar-parts/
Circle Track Racing Radiators | SRIPerformance.com
Big Dave
Larger Dave is online now
post #23 of 32 (permalink) Old Feb 8th, 20, 08:44 PM Thread Starter
DeAngelo
One final note don't buy your radiator new. NASCAR makes the race houses take their cars apart every year and build a new one from the ground up. You can find a used C&R radiator designed to cool a thousand horsepower for less than the price of a new Griffin. (depending upon the time of the year).
Big Dave
Good to know! Thanks again, Dave!
67 Camaro RS/SS
4L80e
post #24 of 32 (permalink) Old Feb 8th, 20, 09:06 PM
Darin
ilikeike's Avatar
Kendig did some functional 68 hood vents. They were actually intakes though, not just vents.
They looked bad @$$ !
ID:	232557   Click image for larger version
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is online now
post #25 of 32 (permalink) Old Feb 9th, 20, 04:17 AM
Brett
Another area of concern is the amount of heat being generated by the engine. I put a 454 in my 72 Chevelle and I could feel the heat coming off the engine. Come to find out, the hedder primaries were putting off 500 degrees! They were much too small for a 454 with a 671 Blower. I replaced them with headers with much larger primaries and the problem was solved. Not saying this is your issue, but it could be a contributing factor. But I think I've brought this up before and I think you replied that this area has been addressed.
Brett....
Rockets Up In 2020!
Brettallen59 is offline
post #26 of 32 (permalink) Old Feb 10th, 20, 02:35 PM Thread Starter
DeAngelo
Those are sweet! And surely expensive!
Brett....
Thanks, Brett. The headers are 2" and BluePrint says they are ok for that motor.
67 Camaro RS/SS
4L80e
post #27 of 32 (permalink) Old Feb 10th, 20, 03:10 PM
Cowl hood does little also since it opens to an area of high pressure at the base of the windshield.
FWIW I feel air coming out the rear of my cowl hood from the radiator fan, at least at idle as I held my hand over it the other day and air is definitely being "pushed" out. Heat will purge itself through the rear opening of the cowl
I get OP wants to keep his ice tray hood. I also saw the Kindig build. IIRC it was a modern LTx motor though.
"Custom" screens could be made to act as vents. How effective those would actually be IDK.
Big fing radiator with good high output (cfm) fans to manage engine temps. Also if running headers they need to be ceramic coated. That GREATLY reduces header generated heat
I also have the top front cover, aftermarket, that in principal keeps incoming air (while moving) directed through radiator. A friend gave it to me because he wanted a chrome one. IMHO they are high $ but the non chrome ones are $100+ which I think will benefit cooling while moving. Firebirds had a 2 piece one IIRC but not the Chevy
SoCal805 is offline
post #28 of 32 (permalink) Old Feb 10th, 20, 03:14 PM
I was referring to when moving at speed, not sitting at idle. The cowl hood is intended as an air intake, and it is an area of high pressure at speed. Thatís why it was designed that way for an intake, not an exhaust....
post #29 of 32 (permalink) Old Feb 10th, 20, 05:15 PM
As Kevin suggests, having a close-out panel for the top is good idea and supplement it with a similar panel on the bottom.
Anything preventing re-circulation of engine air is helpful. A panel from the support to the valance panel.
If you want to go further, make a couple for the headlamp buckets.
Doing a good job is like peeing in your dark pants Ö you get a warm feeling, but nobody notices
post #30 of 32 (permalink) Old Feb 10th, 20, 05:46 PM
Modern cars have a six inch plastic dam attached to the bottom of the radiator support. This is not to let you know when you are about to hit the parking curb, but to prevent air from slipping under the radiator support rather than going through the radiator.
Modern EFI cars have a higher temp thermostat so the engine runs cleaner (carbon mon oxide is further oxidized into carbon dioxide thanks to under hood heat and fresh air pumped into the exhaust port behind the face of the exhaust valve.. Break off that air dam (because you haven't learned where the parts of your car is in relation to the driver).and the temp jumps ten to fifteen degrees.
Cadillacs of the seventies had factory tin to direct air into the radiator back when they had a five hundred cube V8 for a power plant.The Caddy with it's bigger motor still ran cooler than the same body (called an Impala) with a SBC. The Caddy radiator was the same size as that used on the Impala if it had a BBC under the hood (B-bodies or "full size" Chevys are the only car except for the Corvette to have the 427 as an optional engine; and was my go to source of BBC builds for years).
Big Dave
