Preferred oil pressure sender location - Team Camaro Tech
 1Likes
  • 1 Post By Bruce1968
post #1 of 8 (permalink) Old May 21st, 20, 10:49 AM Thread Starter
I just got a new create engine and since it is on the stand, I have a bit more of a choice on where I can place the oil pressure sender. I'm using a Dakota Digital dash with its electronic sender. I had it on the top before and it was a tight fight and took two fittings to get it in there. Now, I could mount it in the port down on the block. I wondered if anyone had a preference on where to top it and if so, why?
Bruce1968 is offline
post #2 of 8 (permalink) Old May 21st, 20, 11:57 AM
Re: Preferred oil pressure sender location
FWIW on my LT1 block I used the NPT port just above oil filter adapter (assuming you have one there on your block), DS. I kept the idiot light sender plumbed into the stock, top rear, location
SoCal805 is offline
post #3 of 8 (permalink) Old May 21st, 20, 04:25 PM
Corky
You can use either one, just what ever blows your skirt up. I have a 2nd gen and I use both, side for the idiot light and top for real gauge.
Corky
CorkyE is offline
post #4 of 8 (permalink) Old May 21st, 20, 07:24 PM Thread Starter
I think I'll just stick with the upper location. I already have have the fittings and would rather not go back to the parts store. It think the guy there is getting tired of seeing me.
post #5 of 8 (permalink) Old May 22nd, 20, 07:56 AM
On my 327 motor I have both plumed into the top rear port using a NPT "T", 45 degree. Its tight but both senders fit. The one on front, PS, of motor to me would look "awkward" if I used that port
SoCal805 is offline
post #6 of 8 (permalink) Old May 22nd, 20, 09:14 PM
J.R.
If I were the guy behind the counter, I would welcome all your trips in. Job security in a sense. If he has problems with repeat customers, he needs to look for another profession in my opinion.
J.R.
May you always have Summer in your heart and some Spring in your fanny.
adjudimo is offline
post #7 of 8 (permalink) Old May 24th, 20, 03:26 PM Thread Starter
I was joking.
allanjs likes this.
post #8 of 8 (permalink) Old May 27th, 20, 08:06 PM
Ozzie
News Flash: If the sender is for electric gauges and looks like the Autometer "mini barrel" type, do NOT attach directly to the block. The vibration ruins them.
I changed out all my gauges to electric Autolite II's May/2018. Lasted a little over a year before the oil press needle would peg itself full right or bounce wildly.
Did some research (here and on Summit's site) and apparently "it's a thing."
Now I have it plumbed to the oil port behind the dist with bushings and a small coil of copper tubing. Mounted loosely to the firewall with alarge hose clamp. The copper tubing acts as a shock absorber. Have had no problems since.
'68 Camaro RS
zz383 (2005) rebuilt in 2019
AFR 195s, Quick Fuel 680, 700r4, Detroit TruTrac 3:42s
fastercar68 is offline
