oil pressure location - Team Camaro Tech
post #1 of 8 (permalink) Old May 5th, 05, 07:22 PM Thread Starter
i am looking for some places to pull oil pressure for a BBC... I know one spot is the plug right above the oil filter but is there any other place i can get this from too? I see 2 other plugs on the same side of the motor i am thinking one is water and the other oil?
69 Camaro RS 396bbc
namz111 is offline
post #2 of 8 (permalink) Old May 5th, 05, 07:42 PM
ZZ_430's Avatar
Re: oil pressure location
The 1/8" NPT plugs that are just above the pan rail go into an oil gallery, but if it's a clearance problem at the normal location, how about using a 90* fitting?
The big Autometer sending unit for a electrical gauge even fits on cars with headers doing it that way.
There is also a 1/4" pipe plug at the very front of the block in line with the 1/8" plugs on the LH side.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 8 (permalink) Old Feb 10th, 06, 03:40 PM
I know this is an old post, but what if you were to hook up into one of the oil galley plugs along the block. I have the factory console oil prseeure guage in my 69 convert and it is a real son of @$*! to get to with headers and a 90 degree elbow ! Any suggestions ? Thanks !!
tommydz69 is offline
post #4 of 8 (permalink) Old Feb 10th, 06, 07:54 PM
If you use the OE clip (L35/A9 (#3784832)) on the rear exhaust manifold bolt and then use a couple of battery positive cable clips (L35/A10), you should be able to run the oil pressure line safely to the front-most npt plug on the side of the left rail.. That's what I did. I also sleeved the pressure line in MSD's HeatGuard sleeving just in case..
I have some pics, but will have to upload later.. (Imageshack are doing some maintenace.)
(I once had my oil pressure line rupture when contacting the exhaust header and saw an instant oil pressure loss.. I crapped myself! -but was so relieved to see a puddle of oil under the car, knowing then it wasn't internal.)
BlackoutSteve is offline
post #5 of 8 (permalink) Old Feb 11th, 06, 08:23 AM
Talking Re: oil pressure location
Awsome ! Thanks for the reply ! To tell you the truth I had the line all hooked up above the oil filter and the ferule started to leak causing oil to drip on the headers and smoke like a crop duster going down the road !!!! I'm going to hook it up in the front. This way my wife doesn't hear curse like a nut while i try to get the line hooked up in the other place !!
post #6 of 8 (permalink) Old Feb 11th, 06, 10:51 PM
Here is the image I couldn't post earlier.
post #7 of 8 (permalink) Old Feb 12th, 06, 06:02 PM
Great !! Thanks for the picutre. I have 1/8 copper tubing to hook up. I also have a ton of the brass fittings so I'm in business ! This just made my life a whole lot easier !!! Thanks
post #8 of 8 (permalink) Old Feb 13th, 06, 01:01 AM
1/8" nylon tubing will be even easier..
Oil pressure? 67ragtp Performance 19 Oct 26th, 05 02:32 PM
Oil Pressure Drop BBC 68camtruck Engine 3 May 5th, 05 05:16 AM
Oil pressure sender location 69rag327 Engine 5 Apr 20th, 05 11:47 AM
oil pressure namz111 Engine 3 Apr 13th, 05 06:32 PM
SB chevy oil pressure dawg Engine 4 Apr 3rd, 05 05:26 PM
