water out of the exhausts? - Team Camaro Tech
post #1 of 5 (permalink) Old May 6th, 05, 04:28 PM Thread Starter
I have always wondered what really caused the exhaust to "slobber" out of the exhaust whenever it is warming up on idle,this With choke on and off.
I have always thought it was maybe too rich. I have my 350 idling at about 700 RPMs, timing at 6 - 8 degrees BTDC, and I have carburetor setting at the best vacuum, 18 to 20. (carburetor is Edelbrock 1401 Q-Jet)
Mine seems to slobber more than most.
I guess it doesn't hurt any thing but the exhaust tips.
I do not know if it can really be eliminated or not.
Any opinions?
1969 Camaro Z-11 Pace Car
350cu/300HP -
Convertible RS/SS- Muncie M20 - posi 3.31, 12 bolt
llpainter is offline
post #2 of 5 (permalink) Old May 6th, 05, 04:35 PM
Re: water out of the exhausts?
The natural byproducts of cumbustion are h2o and co2. Guess you're car runs really good?
post #3 of 5 (permalink) Old May 6th, 05, 07:36 PM
Thumbs up Re: water out of the exhausts?
This is also common with the new injected motors.My everyday driver! will slobber out the tail pipe in the winter when I start it and let it sit to warm up. If I let it run long enough it will fill the pipes with water and when I take off it will leave a trail of water behind it.
A lot of manufacturers will drill small holes in the exhaust system so it will drain out. I guess Ford doesn't do that with the Crown Vic's.
supv26 is offline
post #4 of 5 (permalink) Old May 6th, 05, 08:11 PM
Mine drips like a leaky faucet. As long as you aren't losing coolant, you should have no worries.
BPOS is offline
post #5 of 5 (permalink) Old May 6th, 05, 08:44 PM
B
u guyes been behind a new Accord V-6? like a waterfall. one even had rust or water deposits on the chrome tailpips.
Formers: 1969 RS 350, 700HP 1967 Flash-in-a-pan Firebird 400, 2002 Z28 M6 1SC/1SZ
SnakeEyes is offline
water pump removal on 1996 Z-28 pdq123 Heating & Cooling 7 May 9th, 05 12:53 AM
Water in headlights? Joe Harrison Electrical & Wiring 12 Dec 27th, 04 01:48 PM
Water Injection paulm Performance 17 Dec 2nd, 03 08:05 AM
BBC CSI water pump + LWP pulleys? [RyanB] Engine 8 Jul 18th, 02 09:15 AM
Short Water Pump long water pump question sik68 Engine 14 Mar 3rd, 02 05:34 PM
