I NEED HELP!..Im out of ideas! - Team Camaro Tech
post #1 of 3 (permalink) Old May 6th, 05, 06:23 PM Thread Starter
James
Send a message via Yahoo to james7773
OK, The install on the 327 is done. Im trying to start it up, but I get no spark. Well, i take that back...I got spark once when I turned the key off! The dist. is a Mallory, and it has 2 wires coming out of it. One red, and one Black. I assume these go to the pos and neg sides of the coil. I have the wire from the starter hooked to the pos side of the coil, and still no spark. Ive posted some pictures of the setup on my car on my signature link. The album it titled HELP! Ive also replaced the coil figureing that was bad. Still nothing. oh yeah..I do have 12vlts to the coil with the key on. Anyone..please..I have no idea what to do now.
Thanks, James
My 67 RS 327...its a work in progress.
james7773 is offline
post #2 of 3 (permalink) Old May 6th, 05, 06:56 PM
Re: I NEED HELP!..Im out of ideas!
I just wonder if you got the wrong side of the starter for dist power? You might need to check that you are coming off the solenoid. check the factory routing on this ,,, Got Resistor?
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old May 6th, 05, 07:42 PM
I lost the direcitons to my Mallory distrubtor and I called them. The compay was very helpful and sent me a wiring diagram. My car is in the paint shop so I do not have it to look at.
67 Camaro with 388 with Edleborck RPM heads, Air Gap, CC 282S, Tremec TKO
LukeSkywalker is offline
1/4 mile vid clip -- traction ideas? Eric68 Performance 44 Apr 15th, 05 07:47 AM
Long term storage ideas (locations) JHunter Bench Racing 8 Apr 6th, 05 10:18 PM
pulley ideas needed - 1968 302 MO SooperDave Engine 1 May 28th, 04 05:33 AM
Any ideas on what this problem could be? gateruner Troubleshooting 4 Jan 14th, 04 06:56 AM
Running Hot - Looking for some new ideas RockyMtnRacer Troubleshooting 17 Aug 10th, 01 09:58 PM
