DZ 302 Main bolt kit - Team Camaro Tech
post #1 of 12 (permalink) Old May 8th, 05, 07:54 AM Thread Starter
Chuck
Send a message via AIM to ChuckD Send a message via MSN to ChuckD
Does GM make a complete main cap bolt kit with the correct studs for the windage tray? I'd like to use standard bolts and the correct 5 studs. I had a set but sold it with a motor, now I need to replace it for a new engine project. The parts book shows parts individually, but on gmpartsdirect.com, they do not show up. ARP has a full stud kit, but I do not know if it will fit the stock tray and pan without tray mods. They also show a bolt kit, but make no mention of studs for the tray. Can someone help? Thanks!!
Chuck D.
69 Z-28-Glacier Blue, X-77
ChuckD is offline
post #2 of 12 (permalink) Old May 8th, 05, 08:13 AM
Re: DZ 302 Main bolt kit
This is the only PN from GM. These studs are for '68 and later blocks, designed for use with the PN3927135 windage tray and PN465220 Z28 pan, and are sold individually.
http://www.sdpc2000.com/catalog/312/...rnal-Studs.htm
Neil B is offline
post #3 of 12 (permalink) Old May 8th, 05, 08:59 AM Thread Starter
Chuck
Thanks for the info....is the tray part number -135 or -136?
ChuckD is offline
post #4 of 12 (permalink) Old May 8th, 05, 09:20 AM
Jonesy's Avatar
Chuck, the correct windage tray is 3927136
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #5 of 12 (permalink) Old May 8th, 05, 09:33 AM
Question Re: DZ 302 Main bolt kit
Is that number for the early tray or the later tray??
pdq67
post #6 of 12 (permalink) Old May 8th, 05, 10:51 AM
My mistake. My GMPP catalog shows 3927136 as the windage tray that works with the Z28 pan. I also looks like the Z28 pan PN was changed from 465220 to 360450. -Neil
Neil B is offline
post #7 of 12 (permalink) Old May 8th, 05, 10:53 AM
I've been meaning to ask, if you swap out the 5 stock bolts for the windage tray studs, is align-honing the mains ever necessary?
Neil B is offline
post #8 of 12 (permalink) Old May 8th, 05, 12:06 PM
Jonesy's Avatar
3927136 is the number from way back, I have a GM counter parts catalog form 1977 and it's listed as that. The pan for z/28 was 360009 back in the day. This pan and baffle was used on 1967 -69 302's and 70-75 350 with spec hi perf (z28 and Vette)
Jonesy is offline
post #9 of 12 (permalink) Old May 8th, 05, 03:22 PM
Smile Re: DZ 302 Main bolt kit
I found the info on SB windage trays!!
The early flat tray, PN 3769768 is listed as the 'Vette small crank journal block tray and it uses (5) bolts PN 3872718.
PN 3927136 is the '68 and later Z-28 curved tray along with (5) slightly longer bolts, PN 3960312.
I had the early one in my junk 301.
pdq67
post #10 of 12 (permalink) Old May 8th, 05, 08:38 PM Thread Starter
Chuck
Thanks to all for a bit of mystery unravelling....I will continue to look for the balance of the part numbers, nuts, etc. As far as the line-honing, it's always a good idea, but not always necessary. Some posts I have seen say if you use main studs to hold all the caps, line-honing is a good thing for sure. Check the ARP web site. www. arp-bolts.com This holds more info on that product, I believe. Also, do a search here. Lot's of good info. By the way, the stud part number is 14087508, it was 396012 for 68 and up. www.sdpc.com is also helpful. Thanks again,
Chuck D.
ChuckD is offline
post #11 of 12 (permalink) Old May 8th, 05, 10:26 PM
SY1
PDQ don't you wish you had that small journal setup today? One bolt costs as much as a set of five for the medium journal setup.
Just curious what are guys doing with the larger journal 400 blocks when adding a windage tray? Looks like aftermarket is the only way to go unless it's possible to slightly open up the holes on the GM tray?
SY1 is offline
post #12 of 12 (permalink) Old May 9th, 05, 09:38 AM
Yes I do. I put all my crap out in my buddy, Scrouge's barn out in the country around Higbee, MO back in about the summer of '74 when I had to move to Ft. Madison, IA to work at W.A. Schaeffer Pen Co.
Let's see if I can remember what I squirreled away??
A Tri-5 cast-iron B/H, the other half of my 6-banger Fenton header, my in pieces complete junk 301, heads, heads, heads..
A guy "stole" my other trip setup that was off of either a latter, '50's, Cad, J-2 Olds or Pontiac, I never did know which one?? I still have my other three matching trip carb's in my car now but no intake and I still don't know what they were off of but do remember both sets were different??
My Olds and Buick, 215" aluminum V-8's, etc....
I need to go up there onna these days and see if its still under the barn??
pdq67
10 bolt Vs 12 bolt Johnny Boy Wheels & Tires 1 Apr 25th, 05 06:15 PM
rod bolt stretch problems JamesD Engine 7 Dec 11th, 04 09:45 PM
U Bolts - 10 bolt - 8.5 - GM Corporate drew69 Brakes, Suspension & Steering 2 Nov 9th, 03 03:00 AM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 02:45 AM
