67 SS starting problem - Team Camaro Tech
post #1 of 17 (permalink) Old May 8th, 05, 10:26 AM Thread Starter
I just picked up a 67 SS convertable that has not been started in about 8 years. I have put oil in the cylinders and turned it over by hand. I put a new battery in it and tried to start it, but nothing. I have power, but it almost seems that it might be a nuetral saftey switch, but not sure. I don't so much engine work, so I'm looking to the good world of Camaro owners out there to help me. I am new to Camaros, so be nice. If I could get some helpful tips, that would be great.
Thanks,
stevea is offline
post #2 of 17 (permalink) Old May 8th, 05, 10:59 AM
Re: 67 SS starting problem
could be a bad starter, or the nuetral safty switch. You can access the switch, it's on the horseshoe shifter itself, take the cover off, 2 big wires, one purple, one purple with a white stripe. If you don't even get a click when you turn the key, that switch is probably your culprit, could be a frozen soldenoid too tho.
post #3 of 17 (permalink) Old May 8th, 05, 07:54 PM
run a jumper wire from the hot side of the battery to the + side of the coil toss a 1/2 cup of gas down the carb and crank it and see if it tries to fire...dont leave the jumper wire on for to long it's just a quick test to see if it wants to start before you really trouble shoot the system.
'67 RS/SS 350
'67 SS 350
Smoke'm is offline
post #4 of 17 (permalink) Old May 8th, 05, 09:58 PM Thread Starter
thanks for the help guys, i will put your info to the test on monday. maybe you can give me a little more info on the car. i picked this car up for $10,000.
it has the original running gear, i've checked all the #'s out and they all match. everything is in fairly good shape except the carpet and top. it also needs lower quarters. The paint isn't to bad and will last for a few more years. the question is, did i pay to much? I bought it from a friend of mine who was a camaro famatic 20 years ago and he said that it ran well when he parked it. i will try and get a picture of the car soon.
thank, steve
stevea is offline
post #5 of 17 (permalink) Old May 9th, 05, 07:54 AM
hard to say without seeing it, but I'd assume you will get it started, it will probably run ok, and 10g's for a presentable SS convertible is a steal.
post #6 of 17 (permalink) Old May 9th, 05, 05:21 PM
JohnZ's Avatar
Thanks,
Do you mean it cranks over but won't fire, or it won't crank? If it won't crank, jump the big battery cable stud on the solenoid to the outboard small terminal with a screwdriver and see if it cranks (that bypasses the neutral safety switch).
JohnZ
CRG
JohnZ is offline
post #7 of 17 (permalink) Old May 9th, 05, 05:33 PM Thread Starter
it won't even crank over.
stevea is offline
post #8 of 17 (permalink) Old May 9th, 05, 05:51 PM Thread Starter
OK i got the starter to kick over, but it didn't sound like it turned the motor over. i have the spark plugs out of it right now, so that it will turn over easy. if the tourqu converter is low, would it not turn the motor over. thanks for the help, i am just a body man and not a machanic.
stevea is offline
post #9 of 17 (permalink) Old May 9th, 05, 05:56 PM
James
Send a message via Yahoo to james7773
The torque converter would not keep the engine from turning over. When the starter engages, does it make a grinding sound at all? If it does, perhaps the starter gear or flywheel are ate up. With the plugs out, or in for that matter, can you turn the engine over by hand? If not, perhaps the enigne is froze up? I doubt this is the case, but you never know.
James
My 67 RS 327...its a work in progress.
james7773 is offline
post #10 of 17 (permalink) Old May 9th, 05, 06:15 PM Thread Starter
no the starter doesn't grind, it spins great. i have also turned the motor over by hand and it turnes very easily. maybe the motor is turning and i just can't tell with that starter in my ear. i will have me son watch the fan to see if it turns at the same time.
thanks, steve
stevea is offline
post #11 of 17 (permalink) Old May 9th, 05, 06:39 PM Thread Starter
i got it to turn over, i was hitting the wrong stud and it wasn't engaging. now i need to know how to fix the nuetral safty swich. i am wondering if it isn't just corroded from sitting and needs cleaned off? do you need to change out the whole horseshoe shifter?
I have tried to find a camaro book to help me out, but none of the auto stores in my little town have them, so i have ordered one of the internet and it should be here in a few days. i will need to keep getting your help until then. thanks, steve
stevea is offline
post #12 of 17 (permalink) Old May 9th, 05, 08:03 PM Thread Starter
here are some pictures of my 67 SS conv.
http://pg.photos.yahoo.com/ph/aichel...bum?.dir=/6276
stevea is offline
post #13 of 17 (permalink) Old May 9th, 05, 08:25 PM
take off the four phillips screws and the shifter surround will come off (in 3 peices). The backup light switch and the nuetral switch are on the side of the shifter, easy access. The one you want has 2 big purpule wires. Easiest way to test is to unplg them and jumper em with a paper cilip/ Make sure it doesn't touvh anything.
post #14 of 17 (permalink) Old May 10th, 05, 05:44 AM
Kyle
Ok I'm not sure if this will work for you but i had a car that wouldn't start while in park (auto transmission) but when i put it into neutral it would turn over no problem .. it turns out the wire that runs down to the transmission from the shifter and it stretches over time and needs adjustment
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #15 of 17 (permalink) Old May 10th, 05, 07:25 AM Thread Starter
i tried to start it in both neutral and in park. i am going to try and bypass the neutral saftey switch this morning. thanks, steve
stevea is offline
Starting Problem hgerrick Electrical & Wiring 6 Feb 8th, 05 08:14 PM
starting problem shrtrnd7 Troubleshooting 2 Apr 13th, 04 06:45 AM
starting problem bmann2 Electrical & Wiring 5 Jun 19th, 02 07:19 PM
LT1 hot starting problem Robert Higgins Troubleshooting 1 Mar 8th, 01 05:04 PM
Starting (Cranking) Problem Mark W. Winning Troubleshooting 6 Nov 13th, 00 04:51 AM
