Headers Help - Team Camaro Tech
post #1 of 23 (permalink) Old May 9th, 05, 09:52 AM Thread Starter
Headers Help
I have a 1969 Camaro with factory a/c and power steering. I can not find a header that will work. Hooker won't work with a/c and headman won't work with power steering.
BrianBart is offline
post #2 of 23 (permalink) Old May 10th, 05, 09:43 PM
Re: Headers Help
I would call JEGS or SUMMIT and let a sales rep help you, surely someone has your Application.
Rob
Robert
'69 X-33 since 1984
"Its all crazy..."
olympic69 is offline
post #3 of 23 (permalink) Old May 10th, 05, 10:17 PM
Charles
Re: Headers Help
i have faxtory ac and power steering. i am planning on dropping my motor in this thursday night. i can email you some pics of Thorley tri-Y headers and how they fit by this weekend. i've seen pics of the clearance on the power steering side, about an inch or better, but never one of the ac suitcase side. i'll take a pic of both sides for you.
read my sig. this is a HUGE milestone for me!!! yee hawwww!!!! let the fun begin.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #4 of 23 (permalink) Old May 10th, 05, 11:24 PM
Re: Headers Help
Very cool run269!
I bought my car in 1984. It is an Olympic gold, custom interior, rally sport 1969 Z-28 that I have not driven in 20 years- but it is getting close.
Congratulations on the milestone - fire that puppy up!
Rob
Robert
'69 X-33 since 1984
"Its all crazy..."
post #5 of 23 (permalink) Old May 11th, 05, 06:36 AM
Robert
Re: Headers Help
BrianBart,
Hookers will work with factory A/C and PS. The part numbers for 1-5/8 full length is 2451HKR and shorties are 2466HKR. Add a -1 before the HKR for ceramic coated. Be aware if your car sits low the drivers side header on the full length version hangs down a bit more than the right side.
Run269,
I'd like to see those pics as I've always heard the Tri-Y's would not work with factory A/C
Robert
TC member #18
rojo is offline
post #6 of 23 (permalink) Old May 11th, 05, 12:11 PM Thread Starter
Re: Headers Help
Thank Guys, I ordered a pair of hooker 1 5/8" from jegs. I was trying to find 1 3/4" I will see how they fit this weekend. Can you get them in from the up top.
post #7 of 23 (permalink) Old May 11th, 05, 02:45 PM
Re: Headers Help
the drivers side won't, ever, and the pass side won't with the a/c box in the way.... oh well...
post #8 of 23 (permalink) Old May 11th, 05, 07:02 PM
Robert
Re: Headers Help
Edit: Jim's right. Jack it up high and go from the bottom.
Robert
TC member #18
rojo is offline
post #9 of 23 (permalink) Old May 13th, 05, 07:23 AM
Re: Headers Help
Originally Posted by Run269
... i am planning on dropping my motor in this thursday night. i can email you some pics of Thorley tri-Y headers and how they fit by this weekend...
Hey Run269,
Did you install last night as planned? Can't wait to see pics of your Thorleys mounted. Mine are scheduled to arrive this afternoon!
A couple of questions:
> Which Thorleys did you get? Model 375 or 376? Looks like most people use the model 376, but I decided to go with the 375s for my 68 Camaro after talking to a Thorley sales rep.
> I assume you are installing a small block Chevy. Which frame stands and motor mounts are you using? I've heard these can impact header clearance.
Thanks for the info, and good luck with the install.
- Rob C.
68driver is offline
post #10 of 23 (permalink) Old May 16th, 05, 06:13 PM
Charles
Re: Headers Help
o.k. guys,
here's the scoop on thorley's 376 tri-y and factory ac.
THEY DO NOT FIT!!!!!
i have the Z28 frame mounts and a small block.
man it's close though. ac suitcase was off and just when the motor mounts were 1" above the frame stands i installed the thorley's. no shoe horn needed. both from the top too. please note i have no sheetmetal at all forward of the firewall, so the motor went in almost level.
there is right at 1/2" clearance between the header tube and the power steering box. i could have used that 1/2" on the ac side.....argh!!!
the suitcase will actually locate but is touching the pipe and the pipe keeps the suitcase from seating on the firewall by about 1/2". man soooo close. if thorley would just tweek that tube a little more it would work.
but the good news!!!! my HEI dropped right in with at least 1/2" clearance to the firewall. headers are cinched down tight and i'm now hooking up my clutch return spring. uhhh make that fabricating something to make it work. not real sure the hose clamp trick will work with the thorley's unique design.
got my pulleys on back order at summit and just getting all squishy thinking about what to bolt on next.
oh, some more about the thorley's,
when looking from the side of the car there is almost no header showing below the subframe. the top of the 3 sided bolt flange at the end of the header is 1/2"-3/8" away from the floor, AND level from side to side!!
spark plugs, and getting to them. i installed the Accel shorty plugs and could actually get a standard spark plug socket on some of them. others (most) i had to use a regular craftman wrench on. right angle boots will have no problem i think with touching the pipes. by the way i have aluminum angle plug heads. seem that it might be easier to loosen and tighten them from underneath the car.
i also used the GM ZZ4 dipstick tube which works great for headers and crate motors.
header bolts....
the 1" bolts that came with the thorley's seemed grossly short for aluminum heads, only about 3/8"-1/2" of threads going into the head. i decided and used 1-1/4" socket head cap screws. they worked great and only one rubbed the tube going in. i shortened an old allen wrench and put a socket and extension on the other end and tightened away.
well guys, there's the scoop, thorley's and factory ac do not mix. for now i've ordered the ac delete box. perhaps some day i will add vintage air or some other brand of ac.
p.s. just a last thought. changing frame and motor mounts will make no difference with the thorley's i think. after looking at it and pondering it i just don't think moving the motor up down or forward or back will get you enough room to squeeze the thorley's past the suitcase.
Run269 is offline
post #11 of 23 (permalink) Old May 16th, 05, 06:44 PM
Chad
67 Plum's Avatar
Re: Headers Help
Hey Run269 could you modify a Nova suitcase to clear the headers?They are fiberglass very easy to work with.
67 Plum is offline
post #12 of 23 (permalink) Old May 16th, 05, 06:57 PM
Re: Headers Help
Hedmann's work just fine with power steering, thats what I run!
Hedmann Headers - Part Number 65003 ($179)
Also available are the Ceramic Coated versions, Part # 66003 ($438 at summit)
and
Brian Lewis is offline
post #13 of 23 (permalink) Old May 16th, 05, 07:02 PM
Re: Headers Help
Run269 - - Thanks for the info. Pics??
My Thorleys arrived last Friday. BEAUTIFUL HEADERS!! If all goes well, I should be installing in a couple weeks. No a/c on my car though.
68driver is offline
post #14 of 23 (permalink) Old May 16th, 05, 07:18 PM
Charles
Re: Headers Help
67plum,
i have no idea what a nova suitcase looks like. can somebody post a pic?
i thought about carving my case but it's a really nice case so i decided not to destroy it. after all it is vintage 69. worth way more unmolested.
i can't post pics, wah. i don't have a webhost or site yet. but i did take some pics and maybe i can even email them with this crappy netzero.net bullsh...
ohh, sorry, just a little bashing going on there
Run269 is offline
post #15 of 23 (permalink) Old May 16th, 05, 07:21 PM
Chad
67 Plum's Avatar
Re: Headers Help
Nova case is the same as a Camaro but easier to find.
67 Plum is offline
Headers of Choice? rando Engine 18 Apr 26th, 05 06:34 PM
69 BB Headers and exhaust, HELP Hawaii5-0 Engine 3 Mar 14th, 05 06:34 PM
Problem finding shortie headers paul1969 Performance 5 Sep 24th, 04 08:15 PM
Potential of Custom Headers Tski Performance 22 Jan 23rd, 04 07:11 AM
Need help Choosing Headers Joe 69 Engine 9 Mar 8th, 03 04:41 AM
