Olds 402 Swap - Team Camaro Tech
post #1 of 12 (permalink) Old May 10th, 05, 04:16 AM Thread Starter
Olds 403 Swap
Anyone with any information on swapping a Olds 402 and a Olds TH400 into a 69 Camaro? Would it be an easy swap? Is it just a crossmember and Engine mount issue? Any and all help Always Greatly appreciated!!
Thanks..
Out...
xtremdude is offline
post #2 of 12 (permalink) Old May 10th, 05, 06:18 AM
Question Re: Olds 402 Swap
You mean an Olds 403 motor like out of a later Pontiac T/A??
I figure the usual exhaust manifolds/headers deal too as well as what locations are the rad. hoses at? Maybe a rad.???
That and BB springs, etc...
Maybe the driveshaft length too???? Depending if the TH400 has short or long tailhousing???
pdq67
post #3 of 12 (permalink) Old May 10th, 05, 10:37 AM Thread Starter
Re: Olds 402 Swap
pdq67
Yes I meant 403... Sorry.. I was in a rush this morning. It is a Small block.
Thannk for the info.. I will check the olds and see what is what..
Much Appreciated!!
out...
post #4 of 12 (permalink) Old May 10th, 05, 08:31 PM
Smile Re: Olds 402 Swap
Beg to differ here but it is a "low-deck" big block motor is the only diff. between it and the big tall deck 455.
Just a point of clarification is all.. Good motor but some weak in the mains bulkhead areas!!!
pdq67
post #5 of 12 (permalink) Old May 11th, 05, 04:19 AM Thread Starter
Re: Olds 402 Swap
pdq67
Very good info. As I said. I am not very familiar with the engine. So I am Especially appreciative for this info.
Take care. I will keep you posted on it. I have a chance to get the Freshly rebuilt motor and matching 400 trans for about $1100. All he wants is the money the machine shop charged him.
Thanks again.
post #6 of 12 (permalink) Old May 11th, 05, 11:52 AM
Re: Olds 402 Swap
$1100 goes a long way toward freshening a small block and TH350 combo. 2nd Gen F-bodies (late 70s Firebirds) had the 403 as an option, so it would bolt into a 2nd gen car no sweat, but it's not worth the effort IMO.
Here's some good info on the 403. http://www.442.com/oldsfaq/ofe403.htm
Keep in mind when the above page says "bolts in in place of 350", they mean an Olds 350, not a Chevy 350.
For less than $500, it might be worth trying. For $1100 plus whatever pain you're going to have trying to get the thing in and running good, I'd skip it.
Eric
Eric Kammerer is offline
post #7 of 12 (permalink) Old May 12th, 05, 11:30 PM
Joe
Re: Olds 402 Swap
A few things about 1st gen f bodies, on pontiac firebirds from 67 to 69 the engine was mounted differently then on later 70-81 2nd gens. All poncho engines built after 70 have two sets of motor mount bolts for this reason, one set is for 69 and older cars, the other is for 70 and up. Your olds engine will not have properly located engine mount holes, you will have to fabricate your own set. Second the wiring will have to be modified, the starter, alternator and other misc wiring will have to be extended/modified as will the fuel pump, all this stuff is on the other side of the car. I also would be worried about the oil pan not clearing the rear stearing of a 1st gen f body, you might have to modify the oil pan to clear.
Alll in all, for the time and money it would take to swap in a 403 you could have one bad mofo of a chevy engine that would bolt right in.
70 Camaro, 355, th350, 4.10 posi.
74 Trans Am, 400, th400, 2.73 posi.
Joekool1234567 is offline
post #8 of 12 (permalink) Old May 13th, 05, 06:29 AM
I was just thinking that about the only real off-beat swap I would actually do if I had a good motor would be a 500 Cad.!!
And I would even go so far as drill the crank AND put a pilot bushing in it for a stick installation behind the big motor as well as 3.08's or maybe even higher rearend "road" gears for cruising b/c of all the new-found torque!!!!
pdq67
post #9 of 12 (permalink) Old May 13th, 05, 10:15 AM
Re: Olds 402 Swap
didn't the 70-74 Olds Omega (think Nova) have Rocket power? all you'd need is the proper frame stands and engine mounts from one of those cars, and it would literally drop right in.
i say get it, do it, and show it off at the shows. and if you really want to get a reaction, tell everyone that asks that your Camaro is a factory big block car, but the 396 just didn't have enough oomph for ya, so you decided to go with Rocket power. and if they really get pushy, just tell them its a 307 out of an 86 Regal and watch their heads explode..
you don't plan sincerity.
novaderrik is offline
post #10 of 12 (permalink) Old May 13th, 05, 10:52 AM Thread Starter
Re: Olds 402 Swap
Your comments would be what send me over the edge to DO IT!! if I do. Watching heads explode and Jaws being picked up off the pavement are what it is all about.
Thanks..
post #11 of 12 (permalink) Old May 13th, 05, 11:13 AM
Thumbs up Re: Olds 402 Swap
Sorry, my bad!!
I completely forgot that each one of the NOVA cars had their own motors and that everything would bolt right on our S/f's!!
Good going Nova for remembering!!
pdq67
post #12 of 12 (permalink) Old May 13th, 05, 01:27 PM
Re: Olds 402 Swap
Lets not forget good old GM interchangeability.
A friend once put a 427 chevy in a 66 cutlass. It bolts right in using chevalle motor mounts and the stock frame mounts.
I'm reasonably certain that the motor mount throughbolts are exactly the same distance apart on ALL modern GM V8's.
LS1 T56 Swap rmadsen55 Transmission & Driveline 2 Mar 28th, 05 06:29 PM
muncie tailhousing swap Run269 Transmission & Driveline 9 Mar 28th, 05 04:47 AM
engine mods and swap cherokeeman Performance 4 Aug 22nd, 03 01:09 AM
weight of a 67' camaro? CamaroNOTcamero Performance 16 Sep 17th, 01 08:12 PM
Olds 455 ryskey67 Tech 2000 4 Feb 22nd, 01 04:03 PM
