Zoops! - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 10th, 05, 05:03 PM Thread Starter
Ray
Thumbs down Zoops!
Finally got my new small block in the 67. Went to install my fan belts and noticed the pulleys do not line up. I reused my same brackets but installed aluminum pulleys.My 3 groove crank pulley sticks out 1/8"! I double checked to make sure my ati balancer was all the way in and it was.
I shimmed my alternator out. Then pulled the flange on my water pump out 1/8" That solved the inner groove. The middle groove will require some work on my a/c bracket. The outer crank groove (power steering) is actually a hair in.
At this point I dug up my old gm pulleys and double checked everything with straight edge and calipers. Turns out the new zoops forgelite pulley I got is the problem! Any body got the same problem with zoops?
straight edge is on the balancer side of pulley:
Looks like I may be reusing my old stuff, home summit takes it back.
Now I gotta press my water pump flange back in 1/8"! Do I need to remove the back cover and support shaft/impeller assy.? It is a stage 3 stewart components pump with a set screw on the flange that locks to shaft.
Thanks in advance, Ray
sbc, short water pump, vintage air, factory power steering, alt on driver side
Rayzor is offline
post #2 of 4 (permalink) Old Sep 11th, 05, 10:19 AM
Re: Zoops!
A buddy of mine had the same problem on a 454 in his 69 I believe he used his old pulleys.
69 X11 Basket Case
C5 wheels/brakes,Hotchkis,ADDCO,MOOG
69 chevelle
PairOf69's is offline
post #3 of 4 (permalink) Old Sep 11th, 05, 02:08 PM
Wally
Re: Zoops!
I have Zoops stuff on my 67 chevelle, it's dirt simple single groove stuff, perfect fit.
I talked to these guys a lot before I plunked down the cash, they seem like square guys to deal with. I would cantact them and send the picture to them, I'm betting they will make it right.
Gold 67
M.C.C. 559
1967 Malibu
1971 Malibu
muncieman is offline
post #4 of 4 (permalink) Old Sep 11th, 05, 04:40 PM
Re: Zoops!
can't beat the factory engineered stuff for fit and function.
you don't plan sincerity.
novaderrik is offline
polished alum vs chromed? laabs Wheels & Tires 10 May 16th, 05 12:43 AM
got my zoops serpentine pulleys/btacket what a let down.. MY FIRST 69 Engine 13 Jul 13th, 04 06:48 AM
Zoops brackets sherr20 Engine 7 Feb 11th, 04 03:50 PM
