Replacment carb for #4053 DZ - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 12th, 05, 01:30 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Is the Holley 4160 the correct replacement to use? I thought I may get one while my 4053 is off being restored (if it takes 4-6 weeks). I would like to use the dual feed w/o rigging something up. Anyone have a spare?
Gary L is offline
post #2 of 3 (permalink) Old Sep 12th, 05, 01:42 PM
DjD
DjD's Avatar
Re: Replacment carb for #4053 DZ
No the 4160 carbs only have one metering block and your Y block and hard lines won't match up to the carb inlets. You want a 4150 style carb, some list 3310's are 4150's. Another carb that would bolt up but need different fittings at the inlets is one of the Avenger series carbs Holley makes...
...Dennis
DjD is offline
post #3 of 3 (permalink) Old Sep 12th, 05, 02:00 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
http://store.summitracing.com/defaul...h.asp&N=400178
Does this look right? The picture is only a representation. I am not worried about the choke being manual for now. Thanks DJD!
---------------------edit-----------------------
Let's try this. The link does not work.
HLY-65-3310S
$204.88
Estimated Ship Date: Today
Application Show All Brand:HolleyProduct Line:Holley Remanufactured CarburetorsNumber of Barrels:4Carburetor Flange:Square boreChoke:ManualFuel:GasolineSecondary Type:VacuumNew or Remanufactured:RemanufacturedFuel InletualCFM:750Carburetor Finish:SilverFord Kickdown:YesBooster Type:Straight-legThrottle Linkage Type:UniversalQuantity:Sold individually
Gary L is offline
DZ Carb? MrGrumpy Tag Team 8 Jul 31st, 09 11:01 PM
edelbrock carb problems MY FIRST 69 Performance 1 Nov 19th, 04 03:56 AM
Avenger 670 and other carb ramblings... DjD Performance 12 Jul 22nd, 03 09:22 PM
Demon carb issues. Tracy Focht Troubleshooting 25 Jan 1st, 03 03:03 PM
help with '67 396 spitting and sputtering denverRS/SS Engine 6 Sep 25th, 01 06:48 AM
