What's the logic on lifter lube - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 14th, 05, 09:45 AM Thread Starter
Misha
Cool What's the logic on lifter lube
Ok, this may sound stupid, but I gotta ask..................
When adjusting the valves, all the assembly lube is wiped-off the cam when adjusting from #1 firing order to #6, and then back to #1 to install the distributor (the intake is not installed).
The engine will be rotated again when I hook-up the torque converter to the starter plate.
Now doesn't the cam lube need to be there on start-up?
If the lube is "wiped off" during valve adjustment, are the chances of the cam being damaged at start-up a possibility?
I did use GM EOS, and poured it over the holes over the cam in the lifter valley.
Any takers????
Bill K, are you out there????
Thanks.
69ss350 is offline
post #2 of 4 (permalink) Old Sep 14th, 05, 10:12 AM
Re: What's the logic on lifter lube
im build engines for a living and i would recomend assembly lube but the key to preventing start up damage is priming the oil pump before starting.
MIKE STANSELL is offline
post #3 of 4 (permalink) Old Sep 14th, 05, 10:27 AM
DjD
DjD's Avatar
Sure turning the engine over a few times wipes off some of the cam lube but that's the reason you use cam lube instead of oil. Cam lube has a cling property that keeps a coating on the parts even after they have been moved during valve adjustment and such.
Mikes right about pre-oiling as well to insure a sucessful first firing and long lasting engine...
...Dennis
DjD is offline
post #4 of 4 (permalink) Old Sep 14th, 05, 04:54 PM
Smile Re: What's the logic on lifter lube
Cam-lube is a moly-filled grease so won't drip off the lobes and other places you put it like p/r ends and rocker balls and such! Distributor gear too...
Trade names are "Never-Seize" or "Anti-Seize"...
Isky sells it as their "Rev-Lube". Good stuff.
I wouldn't use any of the runny, "oil type", cam-lubes other that good old EOS in with the oil!! Unless I was going to start her up BEFORE the crap can run off everything!!
pdq67
Setting Pushrod Length - Solid/Hydrolic lifter JHunter Performance 2 Aug 2nd, 05 10:19 PM
Can I change just 1 lifter?? Found a bad one. Josh69 Engine 10 Aug 31st, 04 07:18 PM
Rhodes hydraulic lifters jlighthart Engine 13 Feb 23rd, 03 03:45 PM
engine assembly lube grumpyvette Performance 21 Mar 16th, 02 11:01 AM
roller rockers Lil Greg Performance 9 Feb 12th, 01 04:26 AM
