New Engine best suggestions... - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 14th, 05, 06:07 PM Thread Starter
Question New Engine best suggestions...
I just got the 383 in my camaro fired up and running and now I have some questons... FOr the initial start up we used a 10w30 conventional oil and let it run for about 20 min. Then it was drained and the synthetic was put in with a new filter... Now I did not do this it was done by a shop.... If it were me I would have used a straight 30 wt oil for the break in and then used a dino oil for the first 500 miles.... So I guess I am looking for suggestions as to the best corse of action... THe engine runs perfectly holds 54 lbs of oil pressure and keeps a constant 180*. So should I drain out the synthetic and put the conventional oil back in??????
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #2 of 2 (permalink) Old Sep 15th, 05, 05:36 AM
Re: New Engine best suggestions...
You should be fine. A lot of new cars come with synthetic from the factory any more.
Also if thats what the shop did and they built the motor, its on them.
68 Camaro~LSx ~all motor
WHY KEEP ENGINE RPMS under 7000rpm grumpyvette Performance 50 Oct 4th, 05 10:39 AM
Time to scrap the .80 bore and start over (engine build up suggestions) Hobbes9112 Performance 9 Jun 19th, 05 02:38 PM
Engine Swap Sixty-Seven rs Engine 8 May 23rd, 05 09:16 AM
Engine specs... Whats it worth? 68driver Performance 3 Mar 28th, 05 05:01 PM
69 engine i.d. sk8punk Tag Team 4 Jun 30th, 02 08:10 PM
