spark plug gap question - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 15th, 05, 04:37 AM Thread Starter
Marc
What kind of problems could crop up if your running a plug gap of .045 when you should be running .060?
Marc
67 Camaro, 454, TH400, 9" 4.11's
camaro man is offline
post #2 of 3 (permalink) Old Sep 15th, 05, 05:19 AM
Re: spark plug gap question
What do you have that calls for .060 ?
If you run a smaller gap than called for, you may cause some fouling of the plugs (not hot enough spark), but it is easier on the coil.
I run the MSD6al/HEI set up and can go as high as .060 but run at .050 for safety measure, plus it runs clean there.
68 Camaro~LSx ~all motor
post #3 of 3 (permalink) Old Sep 15th, 05, 06:04 PM Thread Starter
Marc
I'm also running the msd-6al. My question was a somewhat hypothetical question to the extreme. I'm running .045 on my plugs and I think I'm having a slight fouling problem. The motor has an occasional miss. I noticed this when I was timing the motor at 3200 rpm. I installed new plugs this spring and have not pulled them yet to check, but the ones I took out were dark brown to blackish. MSD says for motors up to 10.5:1 compression the gap should be .050 to .060. I didn't know that. My motor is 9.3:1 compression. I'm going to move to a .050 gap or just alittle over this weekend to see if that takes care of it.
Marc
Quick spark plug question thorpe67RS Performance 1 Jul 10th, 05 09:18 PM
Spark Plug ? 28ss Engine 1 Jun 6th, 05 08:07 AM
new spark plug wires 6t8bbc Engine 2 May 31st, 05 06:23 PM
Spark plug recommendations - Pro Toplines pls! RickD Engine 3 Nov 7th, 04 08:46 PM
Spark Plug Wire Length Scott Reeves HSV Electrical & Wiring 3 Oct 7th, 03 02:14 PM
