Torque specs for 385 fast burn aluminum heads - Team Camaro Tech
post #1 of 1 (permalink) Old Sep 15th, 05, 12:33 PM Thread Starter
bjj
Can some one tell the Torque specs for a 385 fast burn aluminum heads. Also, is it possible for oil to leak from the bottom of the heads? I hope I can tighten the head bolts to make the leak go away...
Thanks.
bjj is offline
Whats the key to throttle response? 67CamaroD Performance 44 Apr 23rd, 05 09:08 AM
Torque Specs into Aluminum Heads?? sik68 Performance 2 May 28th, 04 03:51 PM
is there a better deal than the fast burn 385? Spames Performance 30 Aug 11th, 03 03:05 AM
400 SBC COMPRESSION RATIO DTL504 Performance 37 Dec 10th, 02 08:39 PM
Aluminum Heads leaking Raidersfan Troubleshooting 4 Aug 6th, 02 04:31 PM
