282 idle - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 15th, 05, 03:56 PM Thread Starter
Big daddy
282 idle
Hey guys,I have a 383 with 282s and 750 vac holley,it run great,but I was wondering what the idle should be.Right now,I'am at about 800 rpm.I think Eric68 had this setup once.Oh,it is a 4 speed.Thanks
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 10 (permalink) Old Sep 15th, 05, 04:44 PM
Re: 282 idle
I would think 750-800 would be about right. The 294s in my 388 will idle at 900-950 easily enough.
travis is offline
post #3 of 10 (permalink) Old Sep 15th, 05, 06:48 PM
Re: 282 idle
I have the same cam in my 383. The idle is much smoother than I though it would be. I was hoping for more of a lope at idle. There is plenty of vacume for the power breaks. The little I have driven my I can say I am very impressed with the set up. Someday I will change the cam to something with more of a lope, I just love the heavy loping sound.
67 Camaro with 388 with Edleborck RPM heads, Air Gap, CC 282S, Tremec TKO
LukeSkywalker is offline
post #4 of 10 (permalink) Old Sep 15th, 05, 08:14 PM Thread Starter
Big daddy
Re: 282 idle
Hey thanks,I thought 800 was about right.Hello Travis,this marvin at&t retired.
carhodge is offline
post #5 of 10 (permalink) Old Sep 16th, 05, 09:51 AM
Re: 282 idle
Yeah, yeah...rub it in So hows the retired life treating you?
travis is offline
post #6 of 10 (permalink) Old Sep 16th, 05, 04:10 PM Thread Starter
Big daddy
Re: 282 idle
Travis,I love it,the money isn't as good,but I get to work on the camaro more.By the way,they contracted be last month to look over the power.
carhodge is offline
post #7 of 10 (permalink) Old Sep 16th, 05, 06:39 PM
Re: 282 idle
They have been contracting out work like crazy. I talk to new people all the time that have only been there for a couple of months. Word on the street (from several reliable sources) is that they only plan to have 1800 employees left when the merger takes place. There was over 130,000 when I started there in 1997
travis is offline
post #8 of 10 (permalink) Old Sep 16th, 05, 07:10 PM Thread Starter
Big daddy
Re: 282 idle
you are most likely right,when I started,there was about 400,000!
carhodge is offline
post #9 of 10 (permalink) Old Sep 16th, 05, 08:55 PM
Re: 282 idle
I'm running a 292H in a 383 and I can idle it with a heavy (strong) lope at 600 rpm. I prefer it in the 700-900 rpm range though, think it sounds better, then run it around at 600-700 in drive. Works good.
Just thought I would throw this in.
Malibu Man is offline
post #10 of 10 (permalink) Old Sep 18th, 05, 02:30 PM Thread Starter
Big daddy
Re: 282 idle
like lukeskywalker said,smooth idle,but it pulls very hard,I like it.
carhodge is offline
getting too hot noels69 Heating & Cooling 14 May 31st, 05 08:53 PM
Holley tuning? railing68 Performance 22 Feb 13th, 05 04:55 AM
My 1st Big Cam/ Trying to adjust Carb/Low Vacuum PERKS67-396 Engine 20 Oct 4th, 02 10:14 AM
Big Cam Bad Idle :( Badcaiman Tech 2002 16 Jul 6th, 02 06:32 PM
Carb air bleeds gear_head_68 Performance 6 Jan 13th, 01 08:00 PM
