motor not running smooth... fixed - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 16th, 05, 07:25 PM Thread Starter
Marc
I'm such an idiot.... I have had several posts before with my motor not running smooth. Two local speed shops went through my carb and one replaced the carb going from a Quick Fuel 950 to a Holley 850 and the motor ran alittle better. I replaced almost every electrical part except the MSD 6 AL ignition system. The MSD 6 AL was next to be replaced. I have done a lot of internet research lately and found a few things that I was doing wrong. My motor was to be timed to 36 degrees. I did not know that was the total timing needed to be done at over 3000 rpm. I was doing this 36 degrees at an idle. I also did not know that the carb needed to be adjusted after the correct timming had been done. On top of all this, I put new plugs this spring and and gapped them at .045. This is what the auto parts store said to gap them at. Come to find out that they should be between .050 and .060 due to the compression of the motor. I gapped them at .054. After correcting the timing, adjusting the carb and cleaning and gaping the plugs to .054 the motor is running as good as when it came off the dyno. I'm heading to the track next Saturday. I will be putting the 950 back on and will adjust it. I'm hoping to run in the high 10's to an 11 flat.
Marc
67 Camaro, 454, TH400, 9" 4.11's
camaro man is offline
post #2 of 2 (permalink) Old Sep 16th, 05, 07:56 PM
Call me Funk
Send a message via AIM to CFunK
Re: motor not running smooth... fixed
"My motor was to be timed to 36 degrees. I did not know that was the total timing needed to be done at over 3000 rpm. I was doing this 36 degrees at an idle."
WOAH!!!!!!!!!!!!!!!!!
Glad you got it sorted out.
-Funk
CFunK is offline
1967 running hot 67ss/rs Troubleshooting 13 Jul 24th, 03 02:27 PM
What is the Ideal Running Tempature Shakenbaker23 Troubleshooting 4 Jan 29th, 03 09:50 AM
Adjusting valves while the engine is running Camaro_Kyle Engine 8 Dec 7th, 02 10:41 PM
Running Hot - Looking for some new ideas RockyMtnRacer Troubleshooting 17 Aug 10th, 01 09:58 PM
AC Always running!!!!!! Ivan Troubleshooting 2 Apr 3rd, 01 07:41 AM
