Positioning rear cam bearing - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 16th, 05, 10:43 PM Thread Starter
Question Positioning rear cam bearing
How far is the rear most cam bearing supposed to be driven in? There is no ridge to stop it from being driven to far. I already know where to clock the hole in the bearing in relation to the hole in the block, but I'm not sure of the front to back placement. I tried installing a spare bearing to test it out. When the bearing oil hole is centered in the groove in the block, it looks like the bearing is to far back. I put in an old cam to see what is happening and it looks like the bearing it sticking out past the edge of the cam by maybe a 1/8". I then installed the bearing to where it was centered on the rear camshaft journal, but then the oil hole was maybe 1/3 covered up with the edge of the groove in the block(only 2/3s of the bearing hole was open to the groove). So what is more important? The bearing hole being fully open to the groove or the bearing being centered on the cam journal. Any suggestions?
JamesD is offline
post #2 of 6 (permalink) Old Sep 16th, 05, 10:47 PM
Larry
Re: Positioning rear cam bearing
I don't remember this being an issue when I've changed out the cam bearinngs. At any rate, I'd definately get the oil hole and groove lined up.
Larry
69-er is offline
post #3 of 6 (permalink) Old Sep 16th, 05, 11:20 PM Thread Starter
Larry
Yeah, I've done camshaft bearings on 2 other engines and I don't remember going through all this. It is a LT1.
JamesD is offline
post #4 of 6 (permalink) Old Sep 17th, 05, 06:34 AM
What bearing part number are you useing.Are you shure they are not for the 283 that used a wide rear beaing.
Rogers Performance is offline
post #5 of 6 (permalink) Old Sep 17th, 05, 06:47 AM
Bill
James.
The bearing should be installed so the hole is aligned with the groove, period. Like Mike said though, you need to make sure you have the correct bearing for the block that you are using. Some of the real early blocks used a wider bearing.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #6 of 6 (permalink) Old Sep 17th, 05, 09:25 AM Thread Starter
The block is a 1997 LT1 for a 1997 trans am. I double check the PN and they are the right ones.
JamesD is offline
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 02:45 AM
Hood adjustments!! Handy69Z Body Shop 2 Mar 13th, 03 05:14 AM
Rear Wheel Bearing Removal Help Mean 69 Brakes, Suspension & Steering 9 Feb 28th, 03 06:26 PM
cam bearing instal at home? what tool to buy cheap caribbean camaro Engine 5 Jun 23rd, 02 03:53 PM
removing cam - it got stuck - I used a pry!!! trouble??? caribbean camaro Engine 11 Apr 5th, 02 01:16 PM
