valve cover removal on 92 camaro v-6 - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 17th, 05, 09:06 AM Thread Starter
do I need to take off the intake manifold to get the passengr side valve cover off of a 92 camaro 3.1 liter v-6. I have a loud tapping on the passenger side valve cover. I need to get it off to see if a rocker arm came loose
mikemeg is offline
post #2 of 4 (permalink) Old Sep 17th, 05, 05:04 PM
a67
Re: valve cover removal on 92 camaro v-6
Yes/no, plenum and runners need to come off. The lower intake stays. Of course that also means the fuel rail needs to be pulled. Quite the pain. The injectors can stay in the rail, and leave the fuel lines connected. The steel fittings into the aluminum rail tend to cross thread way too easy. The rubber feed lines give enough flex to move things out of the way.
If you have some compressed air, blow out the area around the injectors before lifting them out. Grit tends to build up in that area.
Bob.
a67 is offline
post #3 of 4 (permalink) Old Sep 17th, 05, 05:06 PM
Bill
Mike,
I cant answer your question directly, but wanted to let you know to make sure that you dont mix the pushrods up if you end up taking them out for some reason. They are two different lenghts and you dont want to know how many bent valves I have repaired because mechanics did not pay attention to the pushrod lengths
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 4 (permalink) Old Sep 17th, 05, 07:24 PM
Talking Re: valve cover removal on 92 camaro v-6
I just gotta, I just do!!
Doesn't the motor drop out the bottom to pull the valve covers??
Or is that the LAST GEN. cars??
He, He!!
pdq67
PCV location--front or rear of valve cover? Brentmc Engine 3 Jul 26th, 05 10:29 AM
Leak Free Valve Cover Install... dschribs Engine 9 May 3rd, 05 11:32 PM
WP #6 m/t valve cover oil leaking JimM Engine 3 Nov 6th, 04 09:48 AM
2004 SuperCar Reunion Labor Day weekend HawaiianCamaro Team Camaro Cruiz-Ins 1 Aug 25th, 04 09:51 PM
Alternator mounting and valve cover clearance? Joe 69 Engine 0 Mar 15th, 03 04:19 PM
