Upper hose too short - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 17th, 05, 03:35 PM Thread Starter
I put a 383 in a 67 I am doing and will try to make it look as stock as possible.
One problem has cropped up, a stock (aftermarket) upper radiator hose is about 1.5 to 2 inches short, the lower hose and trans lines fit perfect.. any ideas?
TIA
boogieboy is offline
post #2 of 6 (permalink) Old Sep 17th, 05, 03:40 PM
Jody
camcojb's Avatar
Re: Upper hose too short
TIA
What I like to do (especially since my hoses are rarely the stock ones anyway) is to get the parts guy to let you into his hose section and look at what he has. I always find something that fits. If I don't have a hose at all to reference from I take a piece of welding rod or wire clothes hanger and bend it to the shape I need and head to their back room.
Jody
camcojb is offline
post #3 of 6 (permalink) Old Sep 17th, 05, 05:04 PM
Charles
sounds like you have a hose for a small block and a big block radiator.
i believe the 23" radiator would put the top nipple over about 2" more towards the driver side than a small block radiator.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #4 of 6 (permalink) Old Sep 17th, 05, 05:25 PM Thread Starter
It is a 23" radiator for a small block w/ AC. I have tried the AC and non-AC hoses with no luck. Will a BB hose work on a SB?
post #5 of 6 (permalink) Old Sep 17th, 05, 07:07 PM
Charles
i have no idea if the outlet sizes are the same for bb/sb. i've only dealt with the sb's. but i would imagine they are the same.
Run269 is offline
post #6 of 6 (permalink) Old Sep 17th, 05, 07:21 PM
Smile Re: Upper hose too short
One thing you can do cheaply, but it won't look stock is to cut the hose in a straight section and add a pipe spacer using 2 hose clamps!
I had to do it to my SB AND even still have the old made up hose in my trunk.
I cut it where the fan belt cut it b/c of my broken motor mounts back then and added a short piece of sink, chrome drainpipe to keep the fan belt from cutting it again.
Heck, just use the curved ends and run all pipe between them!!
pdq67
Upper rad hose for 23" w/ sbc? GunnerV Heating & Cooling 3 Feb 7th, 04 11:03 AM
Brake Hose upper bracket redesign dnult Brakes, Suspension & Steering 9 Jul 14th, 03 09:50 AM
Upper Radiator Hose Collapsing Bantam Troubleshooting 13 Jan 20th, 03 05:03 AM
Upper Radiator Hose Collapsing tjgerow Troubleshooting 11 Apr 24th, 02 07:40 AM
the right upper radiator hose? denverRS/SS Tech 2000 2 May 15th, 01 07:40 AM
