Re: 327 Combo question
Ok guys tell me what you think of this deal:
Two new Vortec heads
All gaskets to change out heads,intake and cam.
New performer RPM Air Gap intake
Comp cams self aligning ROLLER TIP rockers, balls and nuts
New push rods
New 350 330 H/P vortec GM peformance parts cam Part #24502476
New head bolts and intake bolts
New Comp cams lifters
New black center bolt valve covers
Cost for everything is $1104.00 with shipping
Granny........what are those numbers? I am just curious what your getting. I am told this thing with the RPM intake and 750 Carb is good for 375 H/P !!!
Sounds out there to me and I only plan toa run a 600 or 650 anyway.
Joe
-Mark Donahue
My 67 Camaro Time Line
