Swapping the oil pick-up - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 18th, 05, 02:19 PM Thread Starter
OK...next question.
I'm installing a Miloden low profile pan on my ZZ502 and need to swap the oil pick up. The pan is off, how do I get the old one out and the new one in without busting the pump.
Tim
Meanchicken
68 SS
ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar
87 Buick Grand National (does 10's)
Meanchicken is offline
post #2 of 3 (permalink) Old Sep 18th, 05, 06:53 PM
Bill
Re: Swapping the oil pick-up
Tim,
Is the pickup welded to the pump ? If not, it should come out with some twisting but ... you really need to have the correct tool to press the new one in place. See if your machine shop has one and bring them the pump and let them install the pickup. It would be a good idea to TIG weld the new pickup in place while you are at it. You can "bang" the new pickup in place with an open end wrench if it has a flange on it, but the tool works much better. Either way, its a lot easier with the pump sitting on the work bench.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 3 (permalink) Old Sep 18th, 05, 08:56 PM Thread Starter
Thanks.
I've pulled the pump and will have a local shop R&R the pick-up. I started at it and couldn't keep it in my bench vice while trying to remove the old pick up.
I won't need to weld the new one in since it has a bracket that bolts to the pump housing that will keep it in place.
Tim
Meanchicken
68 SS
Z28 oil pump pick up question. 69Z28 Engine 10 Mar 10th, 06 07:21 AM
Milky oil....Help! Gary68SS396 Engine 5 Sep 20th, 05 12:51 PM
After engine break in I inspected my oil filter, here's what I found. ck 2 Engine 10 Jul 17th, 05 10:05 AM
Oil leak problem......in our 67 67 4 US Engine 5 Jun 1st, 05 09:40 PM
67 Oil leak problem from "H" 67 4 US Troubleshooting 2 May 20th, 05 07:35 PM
