timing issue - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 18th, 05, 06:30 PM Thread Starter
Derek
timing issue
I just got my 350 running in my 68. I havent put a timing light on it but with some help from a buddy, we got to run and idle and restart decent. Only problem is my dist vac advance is right against manifold runner. Dist is an HEI and manifold is edelbrock performer. Could I have the dist in a tooth off.
dtm1968 is offline
post #2 of 3 (permalink) Old Sep 18th, 05, 06:40 PM
Re: timing issue
yes, but... to fix it, you need to move each wire clockwise one position on the cap, then push the vac advance cam back toward the firewall exaclt one wire positition on the cap.
Did I get it right this time? been having a backward weeek!
post #3 of 3 (permalink) Old Sep 18th, 05, 06:55 PM
JohnZ's Avatar
Re: timing issue
If the wires are correctly indexed in the cap (#1 wire where it belongs), you're a tooth off (which is 27* of distributor housing rotation) - pull the distributor, rotate the rotor clockwise a tooth, and re-stab it; that will give you more clearance to the intake runner and leave the wires correctly indexed. The pic below is a points distributor, but it shows the correct position of the vacuum advance can:
JohnZ
CRG
JohnZ is offline
Carb/ Timing Issue???? Oldyeller69 Engine 10 Aug 27th, 04 10:11 AM
Vacuum advance or not??? Ethan67 Performance 55 Apr 9th, 04 06:50 PM
Timing Issue My69Maro Performance 4 Feb 11th, 04 04:13 PM
Ignition Timing Strange Problem Mean 69 Engine 29 Apr 4th, 02 10:10 AM
Timing chain issue Mr Clean Tech 2000 4 Jun 12th, 01 04:48 AM
