Miloden low profile pan - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 18th, 05, 09:07 PM Thread Starter
I'm installing the Miloden low profile pan on my ZZ502. During trial fit, all but three of the bolt holes on one side towards the rear of the pan line up well enough to get the bolts in staight and start the threads. The back three holes on the oil filter side near the filter mount are off by a bit to the outside. Is there any harm in drilling these out a little larger so I can get the bolts lined up, or do you recommend I send this pan back to Summit for a replacement?
The pan edge also overhangs the oil filter mounting point a bit.
I'm using the stock one piece gasket. Should I be using the Miloden one piece gasket?
Tim
Meanchicken
68 SS
ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar
87 Buick Grand National (does 10's)
Meanchicken is offline
post #2 of 3 (permalink) Old Sep 19th, 05, 10:07 AM
Re: Miloden low profile pan
Somethings goofy with that pan! I'd ship it back to Summit. Mine was right on the money as far as fittment goes. The stock pan gasket will work on that pan. I bought a new gasket from GM just to be safe, since the gasket was already set up for that stupid truck pan they send with it.Can you just imagine how many of those pans are hanging on walls? I could'nt give mine away at the last swap meet! Here are the part numbers I used; Oil pan gasket, GM #10106407 Milodon oil pan #30955 (This is a Jegs#)
Catrancher
catrancher is offline
post #3 of 3 (permalink) Old Sep 20th, 05, 02:33 PM Thread Starter
I decided I'll ship it back when I get home from this business trip I'm on...delays, delays, delays...
Meanchicken
68 SS
69 center trunk pan replacement Eric Kammerer Body Shop 9 Nov 18th, 05 09:24 AM
Complete Trunk Pan Replacement Illinois69SS Body Shop 3 Sep 7th, 05 01:47 PM
Full Trunk Pan on 68 sjg34 Body Shop 5 Aug 2nd, 05 04:50 AM
Stock oil pan for 383 1FASTZ Engine 7 Jul 25th, 05 05:33 PM
