ZZ502 Oil Cooler Bypass Valve - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 18th, 05, 09:19 PM Thread Starter
The instructions that came with my ZZ502 say I can leave this in or take it out at my option if I am not running the oil cooler. I've read elsewhere that it's best to remove it as it will give me about 5+ psi more oil pressure if I remove it.
My question is; How do I remove it?
It's the valve down inside the center hole that the oil filter attaches to per the diagram in my instructions, but the instructions don't tell you how to get it out of there.
Any recommendations on which oil filter to run on this engine? I've heard the stock AC Delco PF1218 filter is the best way to go.
Tim
Meanchicken
68 SS
ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar
87 Buick Grand National (does 10's)
Meanchicken is offline
post #2 of 4 (permalink) Old Sep 19th, 05, 12:14 AM
Re: ZZ502 Oil Cooler Bypass Valve
Do you have any pics or can you post the instructions?
BlackoutSteve is offline
post #3 of 4 (permalink) Old Sep 19th, 05, 05:42 AM
Bill
Tim,
You can usually pry them out with a screwdriver. They get mangled in the process, but you are not using it anyway. We also have a "hook" tool that we grab the tough ones with and pull them out. They are not in there very hard.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 4 (permalink) Old Sep 20th, 05, 02:37 PM Thread Starter
Thanks, BillK.
Can you post or e-mail me any pics of the process of getting the oli cooler bypass valve out and the tool you use?
Thanks!
Tim
[email protected]
Meanchicken
68 SS
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
Milky oil....Help! Gary68SS396 Engine 5 Sep 20th, 05 12:51 PM
Oil filter bypass valve sherr20 Engine 8 Nov 27th, 03 05:12 PM
oil filter bypass valve on early big block Mark Mccollum Engine 3 Mar 3rd, 01 05:49 PM
roller rockers Lil Greg Performance 9 Feb 12th, 01 04:26 AM
