327 HP Rating - Team Camaro Tech
post #1 of 27 (permalink) Old Sep 18th, 05, 10:03 PM Thread Starter
327 HP Rating
I am in the middle of rebuidling my 327. I ran the numbers through desktop dyno, but I can't believe the numbers I am getting - nearly 400 HP and torque? Can someone double check me please. Set up listed below
327 Stock Short Block - flat top pistons
Comp Cams HE268
Eldebrock Performer RPM Heads
Eldebrock Performer RPM Intake
750 Holley
Thorley Headers
2.5" Flowmaster exhaust
Did I miss anything?
I am still acquiring parts. Any other suggestions to improve performance?
ghack is offline
post #2 of 27 (permalink) Old Sep 18th, 05, 11:09 PM
Re: 327 HP Rating
400 on the torque Is about right. What flow numbers are you using on the heads?
TJS69 is offline
post #3 of 27 (permalink) Old Sep 19th, 05, 06:16 AM
Thumbs up Re: 327 HP Rating
Imho, a good 327 is a heck of a little motor!
GM got the little bugger just about "dead-nuts" right from the git-go!
That's why it runs so good from the 300hp motor all the way up to the 375hp fuelie one.
It has just a big enough bore to suck good and just a short enough stroke that you can still rpm her right up there! And with only stock, 160 cc heads too, so this is why I say you really don't need a head bigger then a 180 at max.
Gooooood motor!
pdq67
post #4 of 27 (permalink) Old Sep 19th, 05, 04:21 PM
Re: 327 HP Rating
Comp Cams HE268
750 Holley
Thorley Headers
Hey, see how the desktop dyno would read the same stuff but with the cylinders overbored .30 over and oversized valves, (valves from the 350cu-in)
crackyflipside is offline
post #5 of 27 (permalink) Old Sep 19th, 05, 05:31 PM
Smile Re: 327 HP Rating
The valves should be the same size unless the 327 has little 1.72"/1.50" vs the more standard 1.94"/1.50" and hi-po 2.02"/1.60" ones.
pdq67
post #6 of 27 (permalink) Old Sep 19th, 05, 10:29 PM
Re: 327 HP Rating
Ok then, do the same setup but with the cylinders bored .030 over
post #7 of 27 (permalink) Old Sep 19th, 05, 11:02 PM
This is what I get. Don't know for sure on the flow numbers.
327 standard 4.000 bore 358 HP at 5500 , 382 TQ at 4000.
327 .030 overbore (4.030) 359 HP at 5500 , 387 TQ at 4000 RPM
TJS69 is offline
post #8 of 27 (permalink) Old Sep 20th, 05, 11:20 AM
Re: 327 HP Rating
Damn all you get is a 1/5 upgrade?!?
I have been lied to all my life, from this it seems boring the cylinder is useless. Guys, tell me something is wrong here.
post #9 of 27 (permalink) Old Sep 20th, 05, 12:14 PM
Talking Re: 327 HP Rating
Boring a small amount like .030 isn't going to gain you much. Boring is mainly for rebuiling - to clean up the bores. A .030" overbore only adds 4.6 CI. A much larger overbore is not possible as the cylinder bores are to close together.
TJS69 is offline
post #10 of 27 (permalink) Old Sep 20th, 05, 12:18 PM
DjD
DjD's Avatar
Re: 327 HP Rating
Nope, nothing wrong... I think TJS69's numbers are much closer than ghacks... Think about what .030" is in actual size, that's 3 - 100ths of an inch. That's not much extra bore and yet it still shows a small increase... I wouldn't knock that at all. Typically you over bore to remove cyl wall damage or wear. I'd rather have the stock bore and the additional wall thickness when talking about your typical sbc 283, 302, 327 and 350.
...Dennis
DjD is offline
post #11 of 27 (permalink) Old Sep 20th, 05, 12:32 PM
As PDQ67 and Djd are saying is that a small 327 can actually outperform a 327 that has been built up. Forget about a 750 carb. a 600 will work better. The 268 cam is probably too big also. I know now that my cam is too big in my 327, and I have allready changed the carb to a 600. Take PDQ's advice and install a smaller solid lifter cam. If you want, you can always build a 383 for more power !
TJS69 is offline
post #12 of 27 (permalink) Old Sep 20th, 05, 05:03 PM
Re: 327 HP Rating
Im feeling really when somebody says bored 30 over or 40 over is that .030" or .3"???
post #13 of 27 (permalink) Old Sep 20th, 05, 05:28 PM
DjD
DjD's Avatar
Re: 327 HP Rating
Do you have a real name? No offense intended but your screen name makes me feel l'm talking baby talk every time I say it!!
30 over = .030"
40 over = .040"
...Dennis
DjD is offline
post #14 of 27 (permalink) Old Sep 20th, 05, 06:08 PM
Don't take it personally, b/c we tend ta type in shorthand AND I'm really bad about it b/c I will get ta mouthing so trying to get my points across.
Tends to leave the younger and newbie guys on the side..
Don't mean to so please ask if any of us typing something that you don't understand and we will slow down and try to inform you up to speed sorta deal..
pdq67
PS., He, He!! and a couple of us have a habit of wanting to use real names too....
post #15 of 27 (permalink) Old Sep 20th, 05, 06:28 PM
Re: 327 HP Rating
real names r good.... i even used mine in my user id!
327 or 383?.......rpm or torque? makoshark Performance 25 Jun 4th, 06 02:18 PM
327 trouble rigidsporty Engine 27 Jul 31st, 05 02:55 PM
327, 350 or 383? BrewHog55 Performance 5 Jun 27th, 05 07:43 AM
327 balancer Danny Ray Engine 5 Mar 8th, 03 04:56 PM
327 OR 350 mbonazzo Tech 2000 10 Apr 12th, 01 03:34 PM
