argh..... - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 18th, 05, 10:52 PM Thread Starter
Paul
MCGOO's Avatar
argh.....
How is it that as I rebuild the front of my engine the alternator pulley is not aligning with the water pump & crank pulleys.
The alternator mount only fits one way, but I am suddenly looking at the alternator pulley being about 1/2 inch closer to the block that the other two pullies?
This is very frustrating
Paul
'69 Camaro, 250 inline 6, EFI Turbo rebuild is running!!
, CC5S TKO 500, and more.
V8 Camaros are like navels......Everybody has one.
The Toad. 1970 base Camaro (Navel), 350, turbo 700R4, 3.73 posi, Hotchkis TVS system,
Mrs. McGoo's & McGoo Jr.'s toy
MCGOO is offline
post #2 of 7 (permalink) Old Sep 19th, 05, 05:22 AM
Re: argh.....
Since you have a six cylinder, isn't the bracket adjustable in length? I seem to remember the 6-cyl I had did this.
post #3 of 7 (permalink) Old Sep 19th, 05, 09:22 AM Thread Starter
Paul
MCGOO's Avatar
Re: argh.....
Everett,
The lower alternator bracket is non-adjustable. It bolts to the lower portion of the block & positions the alternator on the engine. the upper mount is slotted to allow belt adjustment.
Paul
MCGOO is offline
post #4 of 7 (permalink) Old Sep 19th, 05, 09:52 AM
Re: argh.....
Well, if it was aligned before removal & rework, and no parts have been changed out or swapped, then it should align with others.
Better said then done............
post #5 of 7 (permalink) Old Sep 19th, 05, 12:33 PM Thread Starter
Paul
MCGOO's Avatar
Re: argh.....
That would seem reasonable wouldn't it?
Thus the title of my posting.
There are times when I think to myself that I should save the time & aggrevation & pay to have the work done on my car.
Paul
MCGOO is offline
post #6 of 7 (permalink) Old Sep 19th, 05, 02:09 PM
Tim
Re: argh.....
Well lets see, if the pulley is a 1/2 off, is the top bracket on an angle to the front of the alt? If there was a 1/2 in spacer behind the lower mount would it line up? Or would that throw the top mount off? Is it single pulley on pump, run belt to other pulley?
Trick1 68rs 454 4sp 12blt
Trick1 is offline
post #7 of 7 (permalink) Old Sep 19th, 05, 09:30 PM Thread Starter
Paul
MCGOO's Avatar
Re: argh.....
Unfortunately I cannot use a spacer. The mount bolts onto the side of the block & spacing would push the mount further away from the crank shaft, not further out towards the front of the engine.
I'll take a picture to show the issue.
My other problem is mounting the power steering. I have to carve up the pump bracket to clear the header. right now it is not sitting square & the pulley for it is on an angle.
I'll take everything off tomorrow night & have a look at it again.
Too bad march doesn't make pulleys & brackets for the 6 cyl.
Paul
MCGOO is offline
Glove box locked and no key. ARGH ? What next? RandyB Body Shop 7 Feb 5th, 02 06:08 AM
Argh! - Something (subframe?) is bent in the front end Zach Vonler Brakes, Suspension & Steering 3 Jul 24th, 01 12:33 PM
Shimming a starter - Part 2 argh!! 68SS350 Engine 7 Jul 23rd, 00 05:29 PM
