bent crank pulley: replace or fix? - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 19th, 05, 03:10 PM Thread Starter
Dan
My '68 Camaro w/orig 350 has a two-row crank pulley that has a pretty good wobble to it. The steering pump pulley (on top of it) is straight and runs true. Is there a way to bend back the bent crank pulley or should it just be replaced?
DanW is offline
post #2 of 7 (permalink) Old Sep 19th, 05, 08:52 PM
Re: bent crank pulley: replace or fix?
Probably needs replacing. I have the pulley from my 327 that I am rebuilding. I got a set of March billet pulleys for the rebuild. It has three grooves. If it will work let me know. I will send it to you - free.
ghack is offline
post #3 of 7 (permalink) Old Sep 19th, 05, 10:24 PM Thread Starter
Dan
I sent you a private message.
DanW is offline
post #4 of 7 (permalink) Old Sep 20th, 05, 05:28 AM
Wally
Got any idea how the pulley got bent??? Is it bent or just not fitting in the harmonic balancer??? I've seen the face of the balancer with strange looking marks, like someone beat the crap out of the thing putting it on. That will distort the hole and the pulley won't set flat.
Gold 67
M.C.C. 559
1967 Malibu
1971 Malibu
muncieman is offline
post #5 of 7 (permalink) Old Sep 20th, 05, 06:10 AM
My water pump was like that too. I found a bur <sp> at one thread hole and I must have went in a circle when I tightened up the bolts. Redid the bolts, filed bur<sp> still has the slightest wobble... I may have flexed it or the powder coating is un-even ?
68 Camaro~LSx ~all motor
post #6 of 7 (permalink) Old Sep 20th, 05, 04:05 PM Thread Starter
Dan
The balancer is new and installed with the correct tool. I installed both pulleys with the engine out on a stand. I only noticed the wobble when breaking in the motor. The two-groove pulley came with the car and I added the third outer pulley for power steering. I'm not certain if it wobbled that much before, but I believe I installed everything correctly since the outer pulley doesn't wobble also.
DanW is offline
post #7 of 7 (permalink) Old Sep 21st, 05, 02:59 PM
I wouldn't go running that engine into high RPM range until you fix the pully. The added vibration will do the rotating assembly no favors at all, and could even cause a catostrophic failure if the wobble is severe enough.
Possible failures could range from the pully vibrating loose and richocheting around you engine compartment until it punches a hole through something like your oil pan, hood or radiator. Worse case will include that and your engine grenading under the vibration.
Meanchicken
68 SS
ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar
87 Buick Grand National (does 10's)
Meanchicken is offline
Is is safe to shim the crank pulley???? smith69z Restoration Corner 15 Aug 6th, 05 03:59 PM
Crank pulley and water pump dilema.... Chevy396 Engine 5 Mar 12th, 04 04:39 AM
Crank pulley alignment sherr20 Engine 8 Nov 23rd, 03 06:29 PM
bb crank pulley pace11 Troubleshooting 2 Apr 3rd, 03 05:41 PM
Need help finding a BB single groove crank pulley Joe 69 Engine 1 Mar 28th, 03 05:05 AM
