How to clean lifter bores ?? - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 20th, 05, 08:49 AM Thread Starter
What is the best way to clean lifter bores with surface light rust?
edcorsaro is offline
post #2 of 6 (permalink) Old Sep 20th, 05, 09:02 AM
Royce
Re: How to clean lifter bores ??
I don't know if this is the best way, but it has worked for me over the years. They make a small brake cylinder hone (for honing drum brake cylinders). I usethat with a little tranny fluid for lubrication.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #3 of 6 (permalink) Old Sep 20th, 05, 06:11 PM
Smile Re: How to clean lifter bores ??
That and a little-bitty, dingle-berry hone sized for them too!!
BUT use both of them very easy and DON'T remove much stock at all b/c all you need to do is JUST clean them up smooth!
Otherwise, you can make them a tad too loose if you get carried away here AND it won't be good..
pdq67
post #4 of 6 (permalink) Old Sep 20th, 05, 06:54 PM
Use a brush of some sort. It is too easy to get into trouble with a brake hone.
oger is offline
post #5 of 6 (permalink) Old Sep 20th, 05, 07:43 PM
Bill
Ed,
I dont like brake cylinder hones, they are too coarse and tend to get hung up on the oil holes. The "berry brush" types are ok, we have used them for years, but lately we have been using the abrasive strip type bottle hones, less chance of one of the honing "balls" coming loose and getting in an oil passage. Here is a pic:
http://www.goodson.com/store/templat...3dc722a8ec94a7
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #6 of 6 (permalink) Old Sep 21st, 05, 02:37 PM
Vintage 68's Avatar
If it's just 'light rust' then using a cleaning brush as 'Oger' suggests with a good Rust Penitrating Oil (insert your favorite brand here - I don't want to open that worm can...) will usually clean up the bore so the lifters slide smoothly.
Even though I now have a bore broach set-up for the specific .845" bore - I for years used the procedure 'camaroman' is refering to using a small 3-stone type with fine stones.
It is important to use a light oil and only make a couple quick passes to remove the major rust and defects and not effect the bore diameter and roundness.
I always deburr the lifter bore top and bottom very slightly to make sure no factory machined burrs exist.
I disagree with 'BillK''s statement 'they are too coarse '... To the contrary, most small brake hones use a 240grit or finer stone. The stones on my small 3-stone hone are KD-266's and they are 320grit. KD also sells a smaller stone that is 400grit (KD2004). The "Lisle"#10050 stones are 240grit.
If you compare them to the "Dingle-Berry" type brush hones you will find they are all 180grit - I have looked for 'finer' small berry-brush types but, never found one.
The bottom line is any of these procedures will work depending on the amount of rust and how carefull you are about doing it.
I do fully agree with 'BillK's statement about $hit in the oil passages
No matter which procedure you use - be sure to fully inspect and clean the oil passages or you will be pushing all that ??? through the lifter bores when the engine is started and brought up to temp.
As always JMHO's;
John M.
1968 Convertible
Some trucks
Vintage 68 is offline
Setting Pushrod Length - Solid/Hydrolic lifter JHunter Performance 2 Aug 2nd, 05 10:19 PM
Can I change just 1 lifter?? Found a bad one. Josh69 Engine 10 Aug 31st, 04 07:18 PM
Rhodes hydraulic lifters jlighthart Engine 13 Feb 23rd, 03 03:45 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 02:57 PM
roller rockers Lil Greg Performance 9 Feb 12th, 01 04:26 AM
