Might be a cracked block????? - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 20th, 05, 12:38 PM Thread Starter
Exclamation Might be a cracked block?????
HEY GUYS
I HAVE A 3.1 V6 IN MY 90 CAMARO. I WAS GOING TO LUNCH DURING SCHOOL AND i STOPED AT A LIGHT WHEN MY CAR JUST SHUT OFF, I READ THE TEMP GUAGE AND IT WAS OVER 260. I LET THE CAR COAST DOWN A HILL AND I PARKED IT. I WAS AT A PLACE WHERE I COULD FILL IT UP WITH WATER, THE FLUID WAS ALREADY LOW I FORGOT TO PUT SOME IN, WELL I BROKE DOWN AND I PUT SOME WATER IN IT, LIKE A COUPLE OF SECONDS LATER I WAS RUNING OUT OF THE BOTTOM OF THE ENGINE. SOME GUY SAID THAT IT WAS THE CAP. WE RECENTLY REBUIT IT. I WOULD REALLY APPRECITATE IT IS SOMEBODY COULD HELP ME OUT
THANKS RAY
Camaro90RS is offline
post #2 of 8 (permalink) Old Sep 20th, 05, 12:53 PM Thread Starter
Re: Might be a cracked block?????
If Anybody Can Help Me Out By The Way I Moved The Car About 10 Feet And Now Its Sitting By The Daycare, I Really Need Some Help Quick Cause Im In School Right Now!
post #3 of 8 (permalink) Old Sep 20th, 05, 02:09 PM
Might be a bad water pump though. Try to see where the water is coming from.
ASE Certified Master Collision Tech
Owner of Daves Restoration.
Wanted- '76 Nova SS
Dave Birdwell is offline
post #4 of 8 (permalink) Old Sep 20th, 05, 02:15 PM
BonzoHansen's Avatar
No matter what it is, you probably are not fixing it there (unless it is something simple like a hose). Have it towed home or wherever you plan on fixing it.
Hey, it should be cool now, fill it up with water and drive it home, but watch you r temp gauge; that is why it is there.
And thanks for unlocking the caps.
And don't forget http://thirdgen.org/techbb2/ A great 3rd gen site.
Good luck.
TC Member #13
BonzoHansen is offline
post #5 of 8 (permalink) Old Sep 20th, 05, 04:10 PM
Shawn
were you putting the water in the rad, or overflow?
if it was the rad, you mostlikely have a hole in it, if it was in the overflow, you probably have a loose hose
victimizati0n is offline
post #6 of 8 (permalink) Old Sep 20th, 05, 05:17 PM
Bill
Ray,
Those engines are famous for the intake gaskets failing at letting the coolant get into the engine oil. Pull the dipstick and look at the oil. If it looks like a milkshake, that is probably what has happened. The head gaskets also can fail, but not as often as the intake gaskets.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #7 of 8 (permalink) Old Sep 21st, 05, 04:35 AM
Shawn
Originally Posted by BillK
Ray,
true, but if he is pouring the water in, and it is just pouring back out on the street, i highly doubt it is a gasket.
Just happened to one of my friends, and he found out his overflow tube was disconnected.
post #8 of 8 (permalink) Old Sep 21st, 05, 10:21 AM
If you just rebuilt it, maybe a freeze plug fell out or is loose. If the water is spilling onto the street.
Jon
67 coupe in pieces,
69 coupe in more pieces,
84 Z/28 t-top in just about one piece
Jon13 is offline
big block transmission/shifter question jamesriediger Transmission & Driveline 11 Jul 6th, 05 03:08 PM
engine builder's code of ethics?? / big block oil pressure ?? caribbean camaro Engine 4 Jul 9th, 03 04:05 PM
zz4 cracked block 67killerb Engine 25 Feb 26th, 03 08:25 AM
Big small block Toad Performance 4 Feb 10th, 03 04:32 PM
Warped Head, Blown Gasket, Cracked Block? A69CamRSFrk Tech 2000 8 Jan 3rd, 00 07:28 PM
