Gm Crate Motor ? - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 21st, 05, 06:42 AM Thread Starter
Gm Crate Motor ?
Crate motor - I just purchased a 1969 Z-28 with what the seller called a crate motor in it. Can anyone tell me exactly what it is ?? I looked over GM crate motors and this number is not there. VO523ZZ3 on front pad. The block casting is not real clear but I think it is 57LGSGI. It has Angle plug alumimum heads # 10088113 on it with a GM Bowtie Intake.
Jim Anderson is offline
post #2 of 7 (permalink) Old Sep 21st, 05, 06:57 AM
Re: Gm Crate Motor ?
Welcome Jim!
That would be a ZZ3 crate engine from GM Performance Products (GMPP). It hasn't been made in a while; it was replaced with the ZZ4. Pretty similar specs to the ZZ4, with just a little less compression (9.8:1 or so).
Eric
Eric Kammerer is offline
post #3 of 7 (permalink) Old Sep 21st, 05, 11:25 AM
340 hp, i believe.
you don't plan sincerity.
novaderrik is offline
post #4 of 7 (permalink) Old Sep 21st, 05, 11:45 AM Thread Starter
Originally Posted by Eric Kammerer
Welcome Jim!
Where would I get the specs for the Camshaft ? I assume it it a one piece rear main block, 4 bolt or 2 bolt ? LT-1 block ? Steel or cast crank ?
Thanks, Jim
post #5 of 7 (permalink) Old Sep 21st, 05, 12:17 PM
Should be a 1 piece rear main seal, 4 bolt mains, NOT LT-1.
I believe the cam is the same as the ZZ4. If so, 208/221 @ .050, .474/.510, 112 LSA, hydraulic roller, 1.5 rocker ratio.
As I recall, the ZZ3 used a cast crank, but I'm not sure on that. The ZZ4 has a forged steel crank.
BPOS is offline
post #6 of 7 (permalink) Old Sep 22nd, 05, 09:06 AM Thread Starter
Thanks for the info.
post #7 of 7 (permalink) Old Sep 22nd, 05, 11:32 AM
i recall the cam being smaller than the ZZ4 cam- that's part of where they found 15 hp for the ZZ4.
cast steel crank and "pink" rods with forged pistons sounds right to me.
all things considered ls 1 or a crate carbed motor? phoenixdawg Engine 13 Mar 18th, 05 06:12 PM
Wow! 30+ year old crate motor fires right up travis Bench Racing 1 Jun 21st, 04 01:28 AM
Its time for a new motor...please advise Steve W Engine 6 Oct 19th, 03 11:38 AM
crate motor swap...is it worth it? Buckeye Tech 2000 6 Aug 23rd, 00 04:13 PM
crate motor gam8788 Tech 2000 1 May 20th, 00 05:43 PM
