427 small block specs?
Ok I found a place in Auburn, WA that will do all the machine work on my block. The problem is they have about a 9 month waiting list for their engine guru to get time to build the engine. After talking with them I also came to the realization that they are VERY expensive. I have no problem having them machine the block and balance it but I have checked and can get the parts alot cheaper else where. What I want to do is build a very stout, RELIABLE, pump gas 427 small block. What I need is some specs. What crank, what rods (length) Which pistons and also which heads? I have a World aluminum 400 mains block, and I will also run aluminum heads. Also on the heads I need combustion size. Also which cam? I plan on running a hyd roller. I dont plan on going over 6000-6500 rpm. Thanks alot!!
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Welfare is completely against freedom and the principles of american life, paying people not to work by stealing from the people who do is insanity.
