Holley carb gurus - need some parts advice - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 21st, 05, 08:00 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
I bought a Holley 3310 to use while my 4053 carb is being restored. My Z actually idles with this carb so I can hardly wait to get my 4053 back. But I need a few parts. What fuel inlet filters does this carb use? Also can I get replacement inlet fittings to fit my stock DZ fuel lines? The ones in this 3310 use a larger fitting size. Thanks.
Gary L is offline
post #2 of 7 (permalink) Old Sep 22nd, 05, 05:46 AM
Bill
Re: Holley carb gurus - need some parts advice
Gary,
3310's do not have an inlet filter, at least I have never seen one and I have probably done at least a hundred of those carbs. I am not sure what size your oem line end is, but there are several different inlet "nuts" available that have different internal threads.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 7 (permalink) Old Sep 22nd, 05, 08:01 AM Thread Starter
"Tri-Tip"
Gary L's Avatar
Yes it does. I looks like there should be filters. Thanks.
Gary L is offline
post #4 of 7 (permalink) Old Sep 22nd, 05, 08:30 AM
The factory ones used filters. They looked kinda like a Qjet filter but were bronze. I have no clue where you can get any.
oger is offline
post #5 of 7 (permalink) Old Sep 22nd, 05, 08:34 AM
Carbs with center hung fuel bowls use a spring loaded bronze filter at the inlet. If the 3310 doesn't have a secondary metering block, your stock fuel line will be too long. Since it is for temporary use, I would get one of the Holley dual feed lines and hook it up with rubber hose instead of bending the original lines to fit.
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #6 of 7 (permalink) Old Sep 22nd, 05, 10:42 AM
Vintage 68's Avatar
Thumbs up Re: Holley carb gurus - need some parts advice
Gary;
You are right - it probably had filters...
The original Factory Part #3878261EH List-3310's and the over the counter Holley 3310-1's were 4150 type carbs with Center-Pivot floats and had a 7/8-20 Inlet fitting and a filter behind it. Sort of like a Rochester as 'Oger' said - matter of fact the filters and springs will interchange...
The later (3310-2~?*) over the counter units were a 4160 type that used a rear metering plate v.s. the metering block with servicable jets. They have a smaller 9/16-24 or 5/8-18 size Inlet thread size. These were also down-rated to 750cfm v.s. 780cfm for the earlier version.
* there must be at least 8 versions so far
About the only parts the 4150 and 4160 versions of this carb. tend to have in common is the '134' Main Metering Block.
You can still get a kit from Holley to replace the filters and the springs.
It is part #162-500. It includes both front and rear filters, 2 springs and all the necessary gaskets for under the Inlet fittings.
The 7/8-20 Inlet Fittings are also available from Holley still. Part #26-26 will get you the correct fitting to adapt the standard 5/8 fuel line fitting to the inlet filter retainer.
There are also sizes for all the common 1/4, 3/8" & etc. inlet lines - ask the rep to explain them if you need a different size.
As for a fuel line - Summit sells the "Sergi" line of fuel inlets for Holleys and they have an 'adjustable' one! Part number from Summit is #G3121 and they are under $50.
Summit probably has the fuel filter pack in stock also - although, like lots of other parts, they don't list it in their cat.
Hope some of this helps;
1968 Convertible
Some trucks
Vintage 68 is offline
post #7 of 7 (permalink) Old Sep 22nd, 05, 09:36 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Thanks guys. I actually found everything here in town today! This carb is the 4150 style and will use the stock DZ fuel lines.
Gary L is offline
DZ carb parts olympic69 Restoration Corner 2 Aug 4th, 04 04:19 PM
holley carb flooding out Yellow68SS Engine 5 Apr 14th, 03 10:25 AM
Holley carb number 3205??? Nonni Tech 2002 4 Oct 20th, 02 07:21 AM
HOLLEY TO EDELBROCK CARB SPECIAL PLATE? mark67ss Tech 2002 3 Jul 8th, 02 03:53 PM
holley carb what is it ??? 67rs327 Tech 2000 3 Nov 22nd, 00 05:18 PM
