Harmonic Balancer ??? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 22nd, 05, 06:03 AM Thread Starter
I just got My 327-275 HP 68 Camaro running and the carb needs a little rebuilding,its an Edelbrock of coarse but the ? I have is ,I took the car up the local Vocational School to see if the teacher could adjust the carb and set the timing on it,but he told me that it had the wrong balancer on it,he said it looked like a 350 balancer,it's about one and 1/16 inch thick and about 6,or 6and 1/2 inch in diameter.When he put the light on it he had to retard the light so much that he just barley could see the mark on the balancer.I just put a new Mallory Unalite Distributor In it and I Timed it by bringing it up on compression until it blew my finger off the number one cylinder and then taking the belt by hand and turning it to the "O" mark on the tab and lining up the mark on the balancer,Is there that much of a difference between the 327 balancer and the 350 balancer , if so do they make a timing tape that you can put on the 350 balancer so you can time the thing accuratley or am I going to have to get a 327 balancer and change all my pulleys,,,,any help would be appreciated Thanks Camaro BOB
bdcole_51 is offline
post #2 of 5 (permalink) Old Sep 22nd, 05, 08:39 AM
Re: Harmonic Balancer ???
A 350 h/bal is thicker, 1-1 1/16" on the rim than a 327, 3/4 inch. The width is determined by the crankshaft and its rotating mass. A 350 has more mass inside the crankcase, hence, the thicker h/bal.
Also, year application is different. 68 & older have the timing mark offset from the keyway than a 69 or newer, they are closer in-line. Checking pictures, they have been posted by JohnZ in this section, will confirm this.
The hub the pulleys bolt upon, are the same height among both, so replacement pulleys, I don't think, will be needed.
post #3 of 5 (permalink) Old Sep 22nd, 05, 09:01 AM
Smile Re: Harmonic Balancer ???
The larger balancer is better for your engine, is what my engine builder says.
Are you sure the balancer you have is not larger in diameter ? The difference in timing marks is only about 10 degrees. The 305 has a balancer with the mark at 12 o'clock. Find TDC on your #1 cylinder and note where the timing mark is. Use a "dial back" timing light and set your total timing to 36* using the new mark.
TJS69 is offline
post #4 of 5 (permalink) Old Sep 23rd, 05, 06:34 PM
JohnZ's Avatar
Pre-'69 balancers have the timing index line on the balancer exactly in line with the keyway and pulley bolt hole in the hub, '69-up balancers have the line about 9* counter-clockwise from there (with the "0" mark on the tab on the timing cover moved the same amount). Whatever balancer you use should have the index line in line with the keyway (assuming you have a '68 timing cover on it).
JohnZ
CRG
JohnZ is offline
post #5 of 5 (permalink) Old Dec 9th, 05, 02:55 PM
Ray
Send a message via AIM to GogglesPisano Send a message via MSN to GogglesPisano
Anyone have balancer P/N's for '67 through '69 handy?
GogglesPisano is offline
harmonic balancer bolt cajunbaby100 Engine 3 Jun 7th, 05 05:18 AM
Harmonic Balancer Question CamFrk68 Engine 3 May 5th, 03 06:07 AM
How far on does the harmonic balancer go ? JMD Engine 4 Jun 16th, 02 03:32 PM
Harmonic Balancer Problem HELP!!!!! DTL504 Engine 6 Jun 9th, 02 08:59 PM
Which Harmonic Balancer? Sleepy-69 Engine 12 Aug 21st, 01 09:27 AM
