carb drill bits - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 22nd, 05, 08:16 PM Thread Starter
carb drill bits
Does anyone know where I can get a set of wire gauge drill bits? I have seen them at local hw stores and hobby shops, but they are not long enough. I need sizes 70-61 (.0280"-.039"), but they also need to be 2 inches long.
Any suggestions?
BTW I'm trying to enlarge the idle/transition ports on a q-jet
Thanks,
Jeff
327camaro67 is offline
post #2 of 3 (permalink) Old Sep 22nd, 05, 08:59 PM
Re: carb drill bits
We sell them where I work in Omaha Ne. (Fuchs Machinery)
Any industrial supply house should have them.
You will need "taper length" drills. They are longer than standard drills.
Some of the national chains that will have them are:
MSC Industrial Supply mscdirect.com
Here's MSC's page. You can buy the individual sizes..
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=48
McMaster Carr
Travers Tool
WW Grainger
Brichead
brichead is offline
post #3 of 3 (permalink) Old Sep 23rd, 05, 04:10 PM
Re: carb drill bits
Just FYI: I have tapped the tubes #0-80, threaded in a screw and pulled the tubes out for adjustment. On 1 out of 12 the tube pulled slightly through the sleeve and buggered it up, but I just replaced it with one from a junk carb.
TTFN
Mat
SSCARGO
Mat Klemp is offline
DZ Carb? MrGrumpy Tag Team 8 Jul 31st, 09 11:01 PM
edelbrock carb problems MY FIRST 69 Performance 1 Nov 19th, 04 03:56 AM
Avenger 670 and other carb ramblings... DjD Performance 12 Jul 22nd, 03 09:22 PM
Demon carb issues. Tracy Focht Troubleshooting 25 Jan 1st, 03 03:03 PM
help with '67 396 spitting and sputtering denverRS/SS Engine 6 Sep 25th, 01 06:48 AM
