Valve covers-Rockers hitting - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 24th, 05, 05:27 PM Thread Starter
jsouthco68camaro's Avatar
I have been chasing rocker noise for awhile now and I think I missed the obvious... The rockers are hitting the valve cover!
I will be switching to tall covers..
My question is why would this happen?
(Car is relativly new to me and loud exhaust was just replaced-May have been there all along!)Car has standard rockers, No rollers.
COuld this be causing any other issues Im seeing ?(White/blue Smoke?)
jsouthco68camaro is offline
post #2 of 6 (permalink) Old Sep 24th, 05, 05:41 PM
Ed
Re: Valve covers-Rockers hitting
Without knowing your valve lift or which rocker arm covers you have, you might try doubling up on your valve cover gaskets to gain the needed clearance.
freezined is offline
post #3 of 6 (permalink) Old Sep 24th, 05, 05:51 PM
Robert
Good idea on the double up but check out the extra thick gaskets available. The steel core cork versions work real well but can get pricey in the $30 range.
Robert
TC member #18
rojo is offline
post #4 of 6 (permalink) Old Sep 24th, 05, 06:40 PM
Craig
I went from tall Valve covers to regular GM valve covers a couple weeks ago. When i put the new valve covers on the rockers werer hitting the valve covers. When i took the valve cover off i realized the valves next to the baffles on the valve covers were actually scraping the sides of the baffle. Wasnt actually the valves hitting the top of the cover...took a pair of channel locks and squeezed the baffle a bit. Might wanna check that as well...
thorpe67RS is offline
post #5 of 6 (permalink) Old Sep 24th, 05, 06:54 PM Thread Starter
I know mine are hitting the covers. When I pulled the covers, I had 8 lines running across the top of the cover..... I tried doubling up the gasket just now, but it had no effect. When i was listening with a stethoscope on the valve cover, I loosend the covers "T" handles and the sound would change as I did it.
How tall are "Tall" covers? Mine measure about 2.5 " from the side rail to the top...
post #6 of 6 (permalink) Old Sep 25th, 05, 03:44 PM
Craig
My tall covers are 3.5"
who's running tall sbc valve covers? 1Fast69chevy Performance 5 Sep 3rd, 05 07:23 PM
Alum Valve Covers w/ Internal Damage Andrew69 Engine 5 Aug 28th, 05 06:41 PM
Correct valve covers 4sale2u Engine 1 Aug 17th, 05 08:45 PM
rocker hitting valve cover? jks67SS396 Engine 5 Jul 10th, 05 01:48 PM
Center Bolt Valve Covers (GM) Clear Roll. Rockers? Go69 Engine 2 Aug 10th, 04 11:37 PM
