bbc crank pulley - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 25th, 05, 04:51 PM Thread Starter
bbc crank pulley
Just got some pullies from summit . The crank pulley is three groove. It lines up correctly but the 7.8" diameter is to large for my 69 it hits the frame. Does anyone know where i can get a pulley that is a smaller diameter for my 454. Thanks Chris
mydogfrank is offline
post #2 of 2 (permalink) Old Sep 25th, 05, 09:53 PM
Wes
Re: bbc crank pulley
Rick's has repo pulley,..two groover for a 375 hp 396, which will have the deep grooves,..$90,..part number CS-291. It will fit, assuming you have the correct BB motor mounts.
If you need the three groover, call March,..they sell nice aluminum V-belt pulleys for most anything.
Good luck
Straight-line-69 is offline
bent crank pulley: replace or fix? DanW Engine 6 Sep 21st, 05 02:59 PM
Is is safe to shim the crank pulley???? smith69z Restoration Corner 15 Aug 6th, 05 03:59 PM
Crank pulley and water pump dilema.... Chevy396 Engine 5 Mar 12th, 04 04:39 AM
Crank pulley alignment sherr20 Engine 8 Nov 23rd, 03 06:29 PM
Need help finding a BB single groove crank pulley Joe 69 Engine 1 Mar 28th, 03 05:05 AM
