Vortec intake gasket question - Team Camaro Tech
post #1 of 18 (permalink) Old Sep 25th, 05, 06:59 PM Thread Starter
Jason
Gambitt's Avatar
Send a message via MSN to Gambitt
I am putting my first set of vortec heads on an engine. I am just about ready to place the intake. The question I have is this...the gaskets I have are felpro, and they are just standard felt...should some type of sealer be used on these, or should I just toss them aside and buy a better gasket that requires no sealer? Thanks in advance for the help.
Gambitt
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #2 of 18 (permalink) Old Sep 25th, 05, 07:22 PM
Lee
Re: Vortec intake gasket question
I used what the general made. They are plastic with a rubber seal. I think they work better, but that is just me.
69Project is offline
post #3 of 18 (permalink) Old Sep 25th, 05, 07:34 PM
Bill Miller
I used those gaskets on my 97 pickup with votecs before the new style gasket came out. that was 4 years ago and there have been no problems with it. I did use spray tach on both sides of the gasket on the felt ones. The new style gaskets are much better I think I would go with them now. I was unsure of the felt ones to but at the time I figured they could not possibly be any worse than the first facktory ones.
1969 RS convertible 327 1981 Z28 original unrestored
BAMiller is offline
post #4 of 18 (permalink) Old Sep 26th, 05, 05:43 AM
Bill
Gambit,
Are you sure the gaskets you have are for Vortec engines ? The original Vortec gaskets, both oem and Fel-Pro, were plastic with rubber inserts. The new Fel-Pro gasket, part number MS98000T is metal with a rubber coating and is really nice. I have never seen a "felt" vortec intake gasket ???
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #5 of 18 (permalink) Old Sep 26th, 05, 07:34 AM Thread Starter
Jason
Gambitt's Avatar
Yeah, it's a vortec gasket. I ordered it from Jegs. I am not sure what type of material it is, it just looks like a thick dark grey paper type material. I would have preferred the fel-pro gasket with the rubber on it, but they didn't show it in their catalog. One more question about this setup...what type of spark plug should be used with the vortec heads?
I just looked that MS98000T gasket up. It runs like $79.00. I will use the $20.00 dollar gasket I have before I pay 79 for an intake gasket.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #6 of 18 (permalink) Old Sep 26th, 05, 10:30 AM
Bill
Gambitt,
The Vortec engines are known for intake leaks filling the engine full of water and killing it. That is why Fel-Pro came out with the new design gasket. Most shops I do work for will not put any other gasket, including the GM one, on those engines. Dont come crying when the $20 gasket kills your $$$$$ engine
You get what you pay for.
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #7 of 18 (permalink) Old Sep 26th, 05, 10:53 AM Thread Starter
Jason
Gambitt's Avatar
Bill,
Yeah, I was afraid you would say something like that And I agree...you shouldn't skimp on a high dollar engine. I had heard good things about the GM gasket...I didn't know that it was having problems too...well, I might have to spend the extra bucks then...Thanks for the info...guess I can always take out a loan
Bill, I found one locally for $60.00, that's bad enough...but maybe I won't die now
Gambitt
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #8 of 18 (permalink) Old Sep 26th, 05, 06:22 PM
Lee
I had a GM gasket fail on my '97 truck and it started leaking water. It didn't "kill it". I replaced it with another GM gasket about 80,000 miles ago and have not had a problem since. When they leak they tend to leak at the rear of the motor for what ever reason.
The $79 you quoted may be for the entire factory intake manifold gasket set. The factory intake on a Vortec engine is a two piece unit (thus multiple gaskets) and the whole set is a little pricey. Make sure you have the right part number. I would check with a GM dealer for the right part number.
post #9 of 18 (permalink) Old Sep 26th, 05, 06:51 PM
Bill
The $79 is for the Fel-Pro new style intake set. It includes one valve cover gasket and whatever else you need to do the job. I sell them for around $68
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #10 of 18 (permalink) Old Sep 26th, 05, 07:11 PM Thread Starter
Jason
Gambitt's Avatar
Yeah, I picked one up this evening. It would be nice if fel-pro would just sell the intake gaskets and not all that other stuff, for those of us using after-market parts. I will put them on one night this week and let you know what I think. Thanks for the info all.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #11 of 18 (permalink) Old Sep 26th, 05, 07:58 PM
Chad
67 Plum's Avatar
Felpro #1255 is an old style felt gasket material gasket with the Vortec and standard bolt patterns.They are for the new Bowtie Vortecs with both bolt patterns.They are about twice as thick compared to standard gaskets.
67 Plum is offline
post #12 of 18 (permalink) Old Sep 26th, 05, 08:00 PM Thread Starter
Jason
Gambitt's Avatar
What sparkplug should be used with these heads? Thanks.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #13 of 18 (permalink) Old Sep 26th, 05, 08:31 PM
Chad
67 Plum's Avatar
We run Autolite 104s.http://store.summitracing.com/defaul...=egnsearch.asp a link to the #1255 gaskets.
67 Plum is offline
post #14 of 18 (permalink) Old Sep 28th, 05, 07:42 AM
got my new style fel-pro intake gaskets at advance auto parts for under $30.i can post part #s later.they are a good bit larger than stock intake ports,but they are the re-usable type.
Eric B
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #15 of 18 (permalink) Old Sep 28th, 05, 09:52 AM Thread Starter
Jason
Gambitt's Avatar
So is the other number because it is a whole kit for a newer model vehicle? If so, I gotta return this whole 65 dollar package and get just the intake gasket.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
Intake manifold gaskets question Darin Imbriaco Engine 2 Jul 13th, 05 05:57 AM
Vortec intake leak AGAIN nitrous383 Engine 8 May 4th, 05 10:05 AM
installing an intake gasket in a 2.8, have questions HotRod53 Engine 6 Mar 8th, 05 04:25 PM
Edelbrock Intake Question rusty Z Engine 5 Jan 26th, 04 06:17 AM
Vortec Intake Manifold Gasket jvenice Engine 2 Sep 9th, 01 01:04 PM
