Alternator bracket won't bolt down (68 350) - Team Camaro Tech
post #1 of 13 (permalink) Old Sep 25th, 05, 07:35 PM Thread Starter
Brent
Brentmc's Avatar
My alternator bracket is too short to attach the top bolt to the thermostat housing. I'm headed to Carlise this week and can try to find something that fits better but need to know what that might be.
Does anyone have any recommendations as to what type of bracket I should try?
Specs: Crate 350, Alternator on the passenger's side, no A/C.
1968 RS/SS Lemans Blue
Brentmc is offline
post #2 of 13 (permalink) Old Sep 25th, 05, 08:07 PM
Re: Alternator bracket won't bolt down (68 350)
You may have to add a shim to the other mount. It might take some juggling, but it looks correct.
TJS69 is offline
post #3 of 13 (permalink) Old Sep 25th, 05, 08:15 PM Thread Starter
Brent
Brentmc's Avatar
I tried to reposition the bracket but it put the alternator out of line with the belts and pulleys.
Here is a better pic of the setup--any recommendations are much appreaciated!
Brentmc is offline
post #4 of 13 (permalink) Old Sep 25th, 05, 08:59 PM
go get an upper alt bracket off a late 70's car or truck and bolt it to that threaded hole on the intake just in front of the water outlet. i'm not sure of the year breaks, but you might need to get a water pump for the same year because they actually changed the top boss that the alternator bracket bolts to for some reason or another.
you don't plan sincerity.
novaderrik is offline
post #5 of 13 (permalink) Old Sep 25th, 05, 09:30 PM
Steven
stamatisg1977's Avatar
im having the same problem
i tried using washers as shims but it just threw the alternator off alignment
the best bet is to go to JEG'S and takea look at thier alternator brackets
like some of thier one arm upper brackets
they look like they will solve our problem
stamatisg1977 is offline
post #6 of 13 (permalink) Old Sep 26th, 05, 04:59 AM
You have a 69 alternator set up, pass side, on your 68, OE being drvr side. Also, you have an aftermarket intake, they never line up with OE brackets, or at least they don't for me.
You can get a thick Gr 5 washer, place it upon the points to be connected, scribe a line on the bracket. Remove bracket & remove paint about the scribe line and weld the washer into place. Then, grind the weld semi-smooth, prime and paint and reinstall.
Try to do something with the third attachment point, having only two attachment points will fatigued the bracket and it will break at the water pump.
post #7 of 13 (permalink) Old Sep 26th, 05, 08:55 AM
Talking Re: Alternator bracket won't bolt down (68 350)
Unbolt the bottom mounting bolt. Remove belt from alternator. Install top (t'stat housing) bolt. Now you will be able to see if shims are needed on lower mount. It will work! Send me a "private message" with your e-mail address, and I can send you pictures of my set-up. NOTE: I do have approx. a .250 shim on the bottom mount.
TJS69 is offline
post #8 of 13 (permalink) Old Sep 26th, 05, 03:55 PM
Alex
Get you hack or chop saw out and chop that part of the braket off! Easy fix! Not a show car thing, but it works!
dragsterman is offline
post #9 of 13 (permalink) Old Sep 26th, 05, 03:56 PM
Alex
Or just get the right brackets for your car.
post #10 of 13 (permalink) Old Sep 26th, 05, 04:17 PM
Shawn
for one thing, take the belts off, hook the bracket up, then put the belt on the alternater, and move it aorund.
looks like you tightened everything up, and nw it wolnt fit.
victimizati0n is offline
post #11 of 13 (permalink) Old Sep 26th, 05, 05:15 PM
Guess
HwyStarJoe's Avatar
I like Derrik's idea. Late 70's early 80's 350 brackets will put that mounting point down on the intake and not at the thermostat housing. Exact same bracket.... just shorter at that mount point.
If you need one, I have one.
HwyStarJoe is offline
post #12 of 13 (permalink) Old Sep 26th, 05, 06:10 PM
I agree with Everett. Looks like you may have a mixture of 68 short water pump with a 69 bracket setup (long water pump). What is the distance from the machined mounting surface of the water pump hub to the water outlet surfaces? That will tell us a lot about your setup.
dnult is offline
post #13 of 13 (permalink) Old Sep 26th, 05, 06:15 PM
Guess
HwyStarJoe's Avatar
I take back what I said. I totally forgot the water pumps were different.
Balancer Issue - bolt or no bolt??? dschribs Engine 30 Jun 4th, 05 05:34 PM
rod bolt stretch problems JamesD Engine 7 Dec 11th, 04 09:45 PM
four bolt main 350 artsylmk Engine 6 Jul 26th, 03 08:58 PM
2 Bolt vs. 4 Bolt hawkeye10 Performance 18 Jan 16th, 03 11:04 AM
4 bolt - converted 2 bolt main rogleete Performance 9 Mar 22nd, 02 01:59 PM
