Hedders - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 26th, 05, 12:28 PM Thread Starter
Hedders
I want to install hedders on my 69 ss 396 anyone out there done this before and what hedder will fit the best, help! Thanks for the response, I have an auto trans(700R4) and power steering, the stock exhaust manifold is very close to the steering gear box already.
rpoppi is offline
post #2 of 4 (permalink) Old Sep 26th, 05, 03:47 PM
Alex
Re: Hedders
Hooker Super comps are nice. They just hang low. It's hard to say, every fist gen I have had seem to be different. Some take headers nice and some need a little help?
dragsterman is offline
post #3 of 4 (permalink) Old Sep 26th, 05, 04:18 PM
Shawn
Re: Hedders
any headers for a BBC should fit.
victimizati0n is offline
post #4 of 4 (permalink) Old Sep 26th, 05, 11:15 PM
Wes
Re: Hedders
I'm using Hooker Super Comps, 2 inchers, the coated version, on my BB. Purchased from Jeg's for $589 plus ship. The Jeg's part number is 05202205-1. I imagine the Hooker part number is 2205-1.
My 69 is a four speed car with no A/C or pwr steer. The issue I had, which is common with most BB headers, is, with aftermarket heads (I have GM Performance O-Ports) I had to use different head bolts with flatter heads so the flanges would line up...(the four lower head bolts on each side just below the header flanges).
Also, the steering box/rag joint has to be removed. Other than that, pretty straight forward.
Nice coating, thick flanges, clear everything fine, and spark plug replacement is a breeze except for # 7 which is reached from under the car (if you have pwr brakes). Also, you'll need to get creative with plug-wire routing to good ol' number 7.
You can also run the larger PF-35 (A/C Delco) oil filter with these headers. Ground clearance is fine but I set my cars up a little higher than most. Oh yeah, I did have to slightly re-route the fuel line (the tank to pump line) from the side of the frame to the top,..no big deal.
Very pleased,..especially after hearing about the torture of BB headers from others.
Good luck!
Straight-line-69 is offline
Hedders rpoppi Engine 1 Sep 26th, 05 04:02 PM
heads and hedders noels69 Engine 5 Aug 17th, 04 06:18 AM
To Hedders or not to Hedders? 4U 2 NV Engine 16 Dec 5th, 03 04:11 PM
sb 327 67' Hedders fit with no mods? r there any?!?! David Bryant Performance 17 Apr 29th, 02 05:24 PM
shorty hedders for a '69 mr69 Tech 2000 10 Sep 25th, 00 06:08 PM
