BB Starter Swap Help
Hey everyone,
I recently purchased a mini racing starter with gear reduction. The description said it would fit 396 applications. I am now finding out that my application requires a special cast iron nose. The new starter has an aluminum nose. The description of the new starter said it was a high output PG260M that replaces the 10MT starter. The description of the new starter gave Delco OEM reference #'s of 9000786, 9000860, 9000899. My question is can I swap the nose from my original starter to this new one or buy just the nose piece at a local auto parts store. I don't want to go through the hastle of returning this thing. I have a 68 SS 396/325. It has the stagared bolt pattern with a 9 tooth gear on the starter. I am assuming it is the larger 168 tooth flywheel because of the stagared pattern? If I can't swap the noses out can anyone suggest a similar starter that will work for me? Thanks,
Dan
