Rubber gasket on air cleaner - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 26th, 05, 08:53 PM Thread Starter
At a recent cruise night a fellow '69SS owner told me that the rubber gasket that sits atop the air cleaner assembly used on a cowl induction hood was put on incorrectly. He indicated that it came from the manufacturer inside out (so to speak) and needed to be turned out the correct way. He said this was a common mistake many people make when placing this part on. I hope I am describing this accurately. Has anyone heard of this?
Steve -
the lip is offline
post #2 of 6 (permalink) Old Sep 26th, 05, 09:15 PM
Re: Rubber gasket on air cleaner
Yes, that is correct. The part of the gasket that has a lip is what goes down on the air cleaner base. The upper part, towards the hood, should be smooth. I've seen this many many times as well.
Donald
68 Camaro convertible (resto on hold)
MytMini is offline
post #3 of 6 (permalink) Old Sep 27th, 05, 07:27 PM Thread Starter
Thank you. Appreciate the confirmation!
Steve-
the lip is offline
post #4 of 6 (permalink) Old Nov 10th, 06, 12:19 PM
Cruzin "the 82"
angelglo's Avatar
anyone have a pic of this?
angel
angelglo is offline
post #5 of 6 (permalink) Old Nov 10th, 06, 12:29 PM
Correct
Incorrect
I had it wrong for ages.. Thought I had the wrong part until someone kindly told me to turn it inside out!
BlackoutSteve is offline
post #6 of 6 (permalink) Old Nov 12th, 06, 12:57 PM
Cruzin "the 82"
angelglo's Avatar
thanks steve. i now can also see mytmini's picture. it was not coming up originally. i guess i had mine the wrong way also.
angel
angelglo is offline
Air Cleaner PCV Hookup for 68 RS/SS SB Manual w/A.I.R aburgess Restoration Corner 0 Sep 8th, 05 06:12 PM
Air Cleaner AJL69 Restoration Corner 3 Aug 4th, 05 09:54 AM
Air Cleaner edd Gordon Performance 1 Jun 17th, 05 03:41 PM
69 Air Cleaner Sticker Unreal Restoration Corner 3 Jun 16th, 05 11:18 PM
air cleaner rubber gasket--removal w/out damaging cturner Body Shop 3 Jul 13th, 02 12:33 PM
