Over Heated 454 - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 26th, 05, 10:36 PM Thread Starter
Over Heated 454
Have a 454 installed in a 89Z,but can only run for about 20 miles before i over heat! Any cool ideas?
NINEVOSS is offline
post #2 of 3 (permalink) Old Sep 27th, 05, 06:33 AM
Question Re: Over Heated 454
Radiator size!
Fan shroud and fan blade location into shroud?
You did burp it and make sure it is completely full?
New 160 to 180 temp. T-Stat and good w/p?
Air flow through the engine compartment?
All for starters.....
pdq67
PS., Oh, almost forgot, do your hoses have coil springs in them to keep them from sucking flat and restricting flow?
post #3 of 3 (permalink) Old Sep 27th, 05, 08:36 PM
Re: Over Heated 454
i have a 85 irocz i wanna swap in a 454, any advice? what trans did you use? did you use the stock rear end ?
454camaro is offline
406 or 454 1bad69+70 Performance 11 Jul 31st, 05 08:46 PM
How olds my 454 ???? Aussie 67 Engine 7 Jun 21st, 05 03:49 AM
454 External balanced MT 68 conv Engine 10 Feb 5th, 05 06:42 AM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 03:08 PM
BBC 396 vs 454... Eric2ndGen Engine 10 Mar 20th, 00 02:14 PM
