Need engine timing basics - Team Camaro Tech
post #1 of 16 (permalink) Old Sep 27th, 05, 09:21 PM Thread Starter
Jason
Gambitt's Avatar
Send a message via MSN to Gambitt
I am getting ready to start my engine soon and would like some info on timing. I would like to hear a few peoples idea of the best way to time the engine for the initial first crank. I looked around and have not found any really good information on this. Thanks.
Gambitt
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #2 of 16 (permalink) Old Sep 27th, 05, 09:55 PM
Wes
Re: Need engine timing basics
Here's the sure fire method for cranking her up for the first time.
1) Rotate the crank by hand until the harmonic timing indicator is dialed in at 6-8 degrees advanced. Make sure the compression stroke was just complete (or more accurately, "almost" completed). If you're not sure, you'll have to pull the driver's side valve cover and watch for the closing of the number one intake valve.
2) Pull the number one plug wire off the spark plug. Then install an old (but working) spark plug in the number one wire boot.
3) Make sure your rotor in the distributor is pointed toward the number one plug wire, or at least close.
4) Loosen the distributor tie down bolt
5) Turn the ignition key to the 'on' position.
6) Ground the old spark plug to engine somewhere,..away from the carb (obviously)
7) Rotate the distributor back and forth in your other hand while you look for a spark from the grounded spark plug. You're trying to pass the number one terminal on the distributor cap past the rotor tip to locate it's positon.
8) Position and maintain the distributor in the position where the spark is achieved
9) Turn the ignition key to 'off' (it shouldn't stay in the 'on' position for longer than a minute, but this method takes about 20 seconds).
10) Tighten the distributor tie down bolt and re-attach the number one plug wire to the plug.
Assuming the fuel supply is good to go, she'll fire right up,.. which is good for engine break-in.
Good luck!
Straight-line-69 is offline
post #3 of 16 (permalink) Old Sep 28th, 05, 05:13 AM
1) Rotate the crank by hand until the harmonic timing indicator is dialed in at 6-8 degrees advanced. Make sure the compression stroke was just completed. If you're not sure, you'll have to pull the driver's side valve cover and watch for the closing of the number one intake valve.
5) Turn the ignition key to the 'on' postion.
7) Rotate the distributor back and forth in your other hand while you look for a spark from the plug. You're trying to pass the number one terminal on the distributor cap past the rotor tip to locate it's positon.
9) Turn the ignition key to 'off' (it's shouldn't stay in the 'on' position for longer than a minute, but this method takes about 20 seconds).
Good luck!
I use the same up to Step 5
Step 6 Turn ON and place AM radio next to distributor.
Step 7 same except turn in CCW direction
Step 8 When "snap" or "static" is heard, stop rotation.
Step 9 Tighten dist holddown bolt.
post #4 of 16 (permalink) Old Sep 28th, 05, 05:46 AM Thread Starter
Jason
Gambitt's Avatar
Thanks, this is exactly what I needed.
Gambitt
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #5 of 16 (permalink) Old Sep 28th, 05, 06:54 AM
The only thing I could add to this is, it will go a lot smoother if you have a helper to turn the key for you. That way, you'll be under the hood, ready to do any adjustments that might be needed. Also preset the idle screw to roughly the second step on the fast idle cam (put the choke on manually, then screw in the curb idle until it touches the linkage to hold it there)
post #6 of 16 (permalink) Old Sep 28th, 05, 09:56 AM Thread Starter
Jason
Gambitt's Avatar
Actually, I have the engine on a stand where it can be started right up. We have used this several times in the past and it works really well. We can start them up and do all the adjustments and work out all the bugs then drop it in the car when done. I usually get help from my dad on timing it, but I always like to get a new perspective on this type of thing...everybody does it differently. I appreciate all the help, I will try and fire it up this weekend.
Gambitt
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #7 of 16 (permalink) Old Sep 28th, 05, 10:01 AM
Christropher
Gambitt
Sounds dangerous starting an engine up on a stand.
Christropher
...in pieces still.
clwilcox33 is offline
post #8 of 16 (permalink) Old Sep 28th, 05, 10:42 AM
DjD
DjD's Avatar
Wouldn't the timing be retarted (atdc) if the compression stroke was completed? I thought to be advanced 6-8 degs the compression stroke would not have reached tdc.
I know this works with points, will it also work with hei/electronic ignition?
...Dennis
DjD is offline
post #9 of 16 (permalink) Old Sep 28th, 05, 01:22 PM
Yes, it does.
post #10 of 16 (permalink) Old Sep 28th, 05, 01:35 PM
Wes
Yes,..the sentence should have read, "make sure the compression stroke is 'almost' complete. The mark on the harmonic should line up with 6-8 degrees advanced,.."advanced" meaning before TDC. I've edited the above.
Yes, this method work with HEI and Points-style distributors,..even points-style distributors that have been converted to electronic (i.e., Pertronix kit, etc.)
post #11 of 16 (permalink) Old Sep 28th, 05, 01:45 PM Thread Starter
Jason
Gambitt's Avatar
Actually, it's not at all. The stand is specially built just for this.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #12 of 16 (permalink) Old Sep 28th, 05, 04:39 PM
Hey post a photo of that stand with the engine in it.
This is so much fun I can't believe it's legal.
69 Camaro- Fastsburn 385 crate, 200-4R
69 Chevelle SS 396 4 Speed
Midlife Cruiser is offline
post #13 of 16 (permalink) Old Sep 28th, 05, 06:40 PM Thread Starter
Jason
Gambitt's Avatar
I'll do it...I should be cranking the engine up this weekend. I will get a pic. Does someone have a spot to host the pic? If so, let me know and I will email it to you. Thanks.
Gambitt
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #14 of 16 (permalink) Old Sep 30th, 05, 08:46 AM
Timing has always been 34 degrees. Anymore and you are just burning off fuel from over jetting, or detonating the pistons out of it!
427ls1 is offline
post #15 of 16 (permalink) Old Jun 2nd, 15, 10:05 PM
Joseph
Sorry guys, I know this is a really old thread but I am ready to fire her up and need confirmation. Can one of these spark tools be used at step 6 & 7?
http://i60.photobucket.com/albums/h2...psf4px3heb.jpg
Good luck!
cam1967rsss is offline
Engine Timing DB Z28 Engine 8 Jun 5th, 04 02:33 PM
EBAY or Build Balboni Performance 16 Jun 3rd, 03 11:16 AM
My 1st Big Cam/ Trying to adjust Carb/Low Vacuum PERKS67-396 Engine 20 Oct 4th, 02 10:14 AM
Setting Timing Without Using Timing Mark Blueandwhite Engine 6 Jun 26th, 02 06:51 PM
timing rodsters Troubleshooting 32 Apr 17th, 01 01:33 PM
