1967 Camaro 350 Ignition wiring question - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 28th, 05, 05:51 PM Thread Starter
Gene
I have a 67 camaro 350 rs/ss that I'm trying to redo. Now, the car had a 350 that was put in before I purchased it so I'm not sure what year it is from, but the Owner said it was from a Z/28. As far as I can tell It's pretty much stock except for the Edlebrock performer intake and Holly 600. My Question is about the ignition switch and wiring. When I first got the car It started and drove fine. But after a while about a week, mid february 2004, I noticed that sometimes the starter wouldn't engage. Crank for two seconds (normal orperation) turn the key off (to keep from leaning on the starter too long) try again and get nothing, like the starter got locked up. So I replaced the starter and everything was fine. Then looking at the wiring and the condition that it was in I decided to replace everything electrical. (Flashback of a story my Dad told me about Grandmother's 68 Mustang burning up). One day (before I ordered the wiring harnesses) while replacing the dash pad, I noticed that there was a burning smell that was coming from under the hood. Once I poped the hood I noticed that the top of the ignition coil had split open and didn't catch fire but was bubbling and pretty much melted the wire half way from the coil to the distributor. In a hurry I disconnected the battery and took out the ignition coil. After getting a new ignition coil and hooking it up to the engine harness I notice that after a couple of minutes the new coil gets really hot. So I ordered the new engine wiring harness from, Classic Industries, and after installing it I get the same result. Then after double checking my wiring I decided to go and change out the distributor (Mallory) to an MSD GM HEI, hoping that this would solve the problem). Before I installed the Msd Distributor I called MSD and they said that it was a drop in ready to run type install where all I had to do was wire the terminal on the distributor cap to a 12V switched source. Simple Right? Well when I tested the Four wires coming out of the ignition switch I have two that are a 12V constant. 1 that is cold when the key is off and at run, but hot at crank. And 1 that is cold when the key is off and at crank but hot while at run. MSD said that I need to find one that is cold with the key off but hot while the car is at crank and run. Right now the car's starter will engage and the engine will rotate but will not start because I have nothing wired to the HEI because I'm still trying to find that 12v switched source. I Thought about grabbing the IGN post at the fuse block but after testing it, it reads 12v constant. Could my problem be with the Ignition switch itself or could the problem be with the wiring of the starter solenoid that I replaced earlier? Also if the wiring is backward on the starter solenoid would the starter even engage? Note that when I replaced the starter the car ran fine untill the incident with the ignition coil. Can any of you help I'm new at this and have already pulled out most of my hair. J/K
Thanks in advance
Mean_Gene3 is offline
post #2 of 7 (permalink) Old Sep 28th, 05, 06:12 PM
Re: 1967 Camaro 350 Ignition wiring question
It sounds like you have a problem with the ignition switch. Just to make sure, take the plug off of the back of the switch and check for voltage at the IGN and ACC terminals at the fuseblock. They should be dead. If they're not you're going to have to dig into the wiring some more.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 7 (permalink) Old Sep 29th, 05, 04:46 AM
Originally Posted by Mean_Gene3
I tested the Four wires coming out of the ignition switch I have two that are a 12V constant. 1 that is cold when the key is off and at run, but hot at crank. And 1 that is cold when the key is off and at crank but hot while at run. Thanks in advance
I believe the ignition switch may be broken internally. You should not have any hot posts/wires except for the red wire (supply) when in the OFF position.
Purple for neutral safety switch
Brown for directional signals
Dark green for inst panel (eng temp)
Two Pinks, one for brake lights, the other to ignition coil.
Welcome to the Club! Hope you enjoy your membership. Newbies buy first round........
post #4 of 7 (permalink) Old Sep 30th, 05, 02:52 PM Thread Starter
Gene
OK cool, Thanks for the quick replies. I have a new ignition switch coming in the mail Monday from Classic Industries. I haven't gotten around to checking the IGN or ACC terminals at the Fuse block yet but I plan to do that Tomorrow, I'll let you know what I get.
Thanks again,
Gene
P.S.
Cheers
post #5 of 7 (permalink) Old Oct 1st, 05, 02:02 PM Thread Starter
Gene
OK i just checked everything with the ignition switch unplugged and the "IGN Fused" terminal on the fuseblock is still registering 12v Constantly. The "ACC Fused" terminal reads cold with the key off, hot at ACC, but cold during cranking. The "Lamp" terminal at the fuseblock registers correctly as well as the "BATT" terminal. Does anyone have an Idea what might be causing this?
Gene
post #6 of 7 (permalink) Old Oct 2nd, 05, 11:38 AM Thread Starter
Gene
OK Guys I figured it out. For some reason I felt the need to check the starter wires, thinking that they might have been crossed. But then again if they were crossed the starter, I think, wouldnt engage and the engine would turn. I pulled the header to get closer to the starter and checked the connections anyway and found that the BATT cable was touching the S terminal on the starter solenoid giving me my 12 constant to the IGN Fused terminal at the fuse block. God I must be a moron. Anyway, The problem is solved. I just want to thank Everett#2390 and 12run for pointing me in the right direction.
Thanks guys
Gene
post #7 of 7 (permalink) Old Oct 2nd, 05, 12:50 PM
Glad to hear you got it figured out.
12run is offline
Starter problems - wiring question -help Johnny K Electrical & Wiring 6 Nov 4th, 05 07:20 AM
1967 Camaro Gauge Clock Question Dandeuce Electrical & Wiring 3 Apr 28th, 05 05:48 PM
68 Camaro Coil wiring braber427 Electrical & Wiring 2 Apr 18th, 05 11:17 AM
1967 Camaro 350 Smog setup Rick Stewart Engine 3 Jan 20th, 04 09:44 AM
need a wiring schematic for a 1967 camaro mateo Electrical & Wiring 2 Jun 3rd, 01 05:50 PM
