Starter speed - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 29th, 05, 11:21 AM Thread Starter
Jan
Starter speed
My issue is the starter, or the speed with which the starter turns. When the engine is cold it spinns real fast but once the engine is hot, it hardly turns att all or very slow.
I have been told that the heat from the exhaust pipe is making the coils inside the starter swell up and cause some resistance. Is that true? I have also heard that there is some sort of heat shield I can install to reduce this effect.
What's the real truth?
67 Swedish Convertible
67 Swedish Convertible is offline
post #2 of 9 (permalink) Old Sep 29th, 05, 02:10 PM
Re: Starter speed
The condition is called heat soak. There have been many different remedies for this from heat shields to remote solenoids. I have a heat shield blanket on mine which helps some what. The only real cure I've found is installing a gear reduction starter. I put one of these on a friend's big block Chevelle and it flat out works every time. As soon as I can afford it I'm putting one on my Camaro.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 9 (permalink) Old Sep 29th, 05, 03:53 PM
Re: Starter speed
try bigger battery cables, and if that doesn't work, get a stronger battery.
you don't plan sincerity.
novaderrik is offline
post #4 of 9 (permalink) Old Sep 29th, 05, 04:13 PM
Bob
Re: Starter speed
Something that is not being mentioned above is that a common cause for your problem is too much initial advance on your distributor. Check your timing, you may have too much advance.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #5 of 9 (permalink) Old Sep 29th, 05, 04:25 PM
Shawn
Re: Starter speed
timing would have nothing to do with the starter spinning fast when it is cold, and spinning slow when it is warm.
victimizati0n is offline
post #6 of 9 (permalink) Old Sep 29th, 05, 09:07 PM
Send a message via AIM to mike3026
Re: Starter speed
Your starter sounds like my old one. It worked fine when it was cold, but when it was hot, it would turn over slowly or not at all. My starter was working, but it was very old and was due for a trip to the trash can. I put a new one in, and it worked fine. I've heard that that heat cover and the distributor problems are rare compared to just a faulty starter.
1987 Chevrolet Camaro V6 Multi Port Fuel Injection 2.8 Litre
mike3026 is offline
post #7 of 9 (permalink) Old Sep 30th, 05, 09:41 AM Thread Starter
Jan
Re: Starter speed
All your answers makes sence. Thanks a lot!
The battery is "fairly" new. The engine is a nineteenseventysomething, smog 350 that some dumb *** put in instead of the original 327 (which has been ordered with forged crank, 12 kilo pistons and flowmaster headers.(no...my wife is happily unaware at this point). )
However,my limited knowledge of technical english makes me ask: What's a gear reduction starter??
Heat shields and covers i can figure out and deal with but I have never heard that expression, or word, before.
post #8 of 9 (permalink) Old Sep 30th, 05, 09:51 AM
Re: Starter speed
When you say "gear reduction starter" do you mean of those high performance "Mini Starters" that claim 50-80 percent more starting power & 1/3 the size (to clear header heat etc...)
If so, I'm itching to try one of those myself...
1967rsss350 is offline
post #9 of 9 (permalink) Old Sep 30th, 05, 02:27 PM
Re: Starter speed
I am indeed talking about those high performance "Mini Starters". It cranks my friend's 461 cube 10.5:1 CR big block like the spark plugs are out.
12run is offline
Starter issues with Proform starter X33camaro Electrical & Wiring 4 Aug 22nd, 05 09:44 PM
stall speed tech mmcillece Performance 0 May 15th, 05 09:35 PM
Starter Tech JimM Electrical & Wiring 2 Sep 21st, 04 10:41 AM
TH350 to 4 speed starter question BamaBoy Performance 2 Sep 11th, 03 08:07 AM
starter teeth problem. flywheel grinding Marc Engine 6 Jul 7th, 03 02:53 AM
