Water Leaking - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 30th, 05, 07:50 AM Thread Starter
Water Leaking
I have a 96 Camaro, and when I went to put water in the radiator and started the car I noticed that some water was comming out right above and behind where I just repalced the water pump. Is this where my head gaskets are located? What could this mean? help
I_love_my_Camaro is offline
post #2 of 3 (permalink) Old Sep 30th, 05, 08:35 PM
Question Re: Water Leaking
I am flat not up on your motor so ALL I can say is go to a site that is into your car and ask..
Sorry, can anybody else help him out??
pdq67
post #3 of 3 (permalink) Old Sep 30th, 05, 10:09 PM
ZZ_430's Avatar
Re: Water Leaking
Very possibly the intake gasket.
Check the places where the intake manifold and heads meet. If it's just pouring out, you should easily be able to see it. Don't rule out the thermostat housing either.
I would use a cooling system pressure tester to eliminate guess work.
Also check the engine oil for coolant contamination. If it's real bad, the oil will look milky.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
Leaking water neck saga continues............ supv26 Engine 6 Mar 14th, 05 09:01 AM
Water neck leaking supv26 Engine 12 Feb 19th, 05 09:00 PM
Water Leaking in doors! Sgrouse Body Shop 3 Sep 3rd, 03 05:32 PM
Water Leaking From Water Pump Bolts rlrr Troubleshooting 3 Sep 7th, 01 08:36 AM
water leaking into car evinphlo Tech 2000 4 Mar 19th, 01 06:07 AM
